Scratch Build – In Progress Baby Moon *Complete*
Discussion in 'Project Logs' started by shinji2k, 12 Jul 2013.
  1. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Yup, I hope there's enough airflow :p.
    You are too kind, thank you.
    I has hoping for a major update today but I'm still waiting on some materials. I can give you this though...
    I'm still tweaking the geometry and waiting on my 3/4" alu rod to make a fake shock absorber for the coil-over. But I can adjust the spring tension though to change the ride height, I'm kinda proud of that :D.
    Hopefully I'll be able to do a complete write up soon.
  2. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Subbed!
  3. Cheapskate
    13 May 2007
    Pretty kick-butt return, there.:D
    If you have any airflow issues, you could make a gasket around the fan and inside wall of the hub.
    -Wait... Pico power supply?
  4. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Thanks!
    Yeah that's plan B. I'll partition it off so the cpu fan sucks in air through one side and exhaust out the other.
    And yeah, definitely reusing a picoPSU from a previous build.
  5. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Update!
    Attached my neodymium magnets and mounted the mobo tray.
    Some materials showed up, time for some lathe work.
    And the coil-over is done.
    Time for the feet.
    I'm still not sure what the feet will end up looking like, but they definitely need some more work.
    It's getting there :D. Thanks for reading.
  6. leonetu
    29 Oct 2013
    May I say that the feet are just screaming for some curves, in keeping with your overall aesthetic? Perhaps the same 'fillet' as in your mobo tray, on top or the outer side of the feet ends? Near the coil, the top could be curved to follow the shape of the bolt.
    That fake coil is just awesome!
  7. Nexxo
    23 Oct 2001
    Is it wrong that I'm getting all tingly with excitement looking at that?... :worried:
  8. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    :D
    I am surprisingly pleased with how the linkage/suspension came together. It wasn't in the original design but it really compliments the gear/sprocket-like body. I'm really excited about this one. Now if I can just get the base right...
  9. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    What about incorporating some imitation knurling? Either crosshatched or straight like this?
    Let's try it...
    Hm....
    I might have to use a checkering file since I'd like to have some curves to the feet.
    edit* I just realized my phone takes better pictures than my old digital camera I've been using...
  10. Cheapskate
    13 May 2007
    Love the feet.:D
    -The checkering looks like torture.
    Notches to simulate airframe lightening?
  11. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    You're in my head. I've settled on hollowing them out with some trussing but I'm not sure the feet at they are will fit with that. I have some other material I can use if necessary. I've been scouring google image for an hour now for some inspiration :p.
  12. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Update!
    I think I finally have the feet sorted!
    Here's a piece where I experimented with all sorts of designs and embellishments.
    Truing up all the edges that need to be straight.
    You like my ghetto 45 deg jig? :p
    This was a design I had dismissed a year ago when I was planning it but it seemed to work quite well with the new suspension setup. I seem to be in the home stretch. I need to go over everything and tweak some things and then I need to epoxy the mobo tray mounts. I also have to decide on the finish. I know the internals and shell will be painted black, but that's all I've decided on. Oh yeah, I need a power button too... :duh:
    Thanks for reading!
  13. Monsieur R.
    Monsieur R. In cornichons I trust.
    1 Dec 2011
    Well, you didn't move a lot for a year, but since last week it's a real aluminium festival. I like it ! :clap: Your work reminds me a lot "Dark Blade", from G69T.
    Oh, and for the internal finish, did you consider anodisation ?
  14. asura
    asura jack of all trades
    22 Apr 2009
    Yea, I posted, blinked, and now look at it! Amazing progress! For the stand my thought would have been (though too late now) to take a cue from a bike/motor-bike stand, making it look like a parked mono-wheel.
  15. Nexxo
    23 Oct 2001
    Must not paint. Must honour the metal. Metal good. Metal pure. Worship the metal.
  16. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I'd love to anodize but I'm not sure I can afford it. I'm currently unemployed so I've been trying to keep spending to a minimum :sigh:. I am worried about actually getting paint into all the grooves, I tried with the scrap pieces and it's tricky. Maybe I can figure something out.
  17. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Update!
    First up for today is the power connector. Since I have the higher watt picoPSU it comes with the Kycon power plug instead of the normal barrel connector. Problem is, it looks like crap and there aren't any other jack available :p.
    So I found some ham radio microphone connectors that look much nicer and should handle the higher current just fine.
    Of course I modified them by machining off the lip that held the knurled nut on to the plug. That nut will then be used to mount the jack.
    Of course I had to tweak the power switch too.
    Used a step drill for the hole to mount the power jack.
    I actually had the odd size tap to fit the threads on the power switch (M7x0.75).
    Time to JB weld the mobo tray mounts.
    What you don't see me doing now is six hours of sanding the body :wallbash:. The paint I bought (ceramic engine enamel) goes on really thin so I really had to prep the surface. The worst part was you could see the tool marks in the outside grooves through paint. So it took three hours with a Dremel and a chain saw sharpener to smooth them out :sigh:.
    But I did get the body and feet painted, those are the only things that will be back.
    The mobo tray and suspension will be raw aluminum. I might put some wax on them since I've never had any luck with clear coat looking right on brushed aluminum. While I give the paint a few days to cure I'll spend some time perfecting the finish on the rest of the pieces and start what little wiring there is.
    Thanks for reading!
  18. AlderonnX
    AlderonnX Minimodder
    10 May 2012
    This is awesome... i shared a link to this log on my facebook. Hope you don't mind
  19. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I don't mind at all.
    Wait, didn't you already ask me that :p
  20. Cheapskate
    13 May 2007
    Deadly shear feet-:thumb:
    black hub for contrast- :thumb:
    ports- :rock:
