Scratch Build – In Progress Baby Moon *Complete*
Discussion in 'Project Logs' started by shinji2k, 12 Jul 2013.
  1. Monsieur R.
    Monsieur R. In cornichons I trust.
    1 Dec 2011
    Great choice of heatsink, I exactly have the same for my own project :)
  2. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Even though I've been following your build, I must have missed your last update. I swear I'm not copying you :p. I happened to stumble over one for cheap on ebay, I really hope it fits :worried:. I think it'll drop temps like 10C in open air, hopefully I see some gains with the side panels on.
  3. Monsieur R.
    1 Dec 2011
    I'm sure you didn't copy. And if it appears that this heatsink sucks, we will be two who made a poor choice :D But I hop it will fit in your case. It has to.
  4. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    One more quick update before I work on some final shots. The cooler showed up and it fits! Under load with the stock fan I'm seeing a 5-10C drop with the side panels on. I attempted to fit the GT to it but even trimming a bunch off the fan it's still ~1/8" too tall. So I did my thing to the stock fan.
    Now I need to find a good place to take some nice photos. The chrome hub caps means you see just about everything surrounding the case so I'm not quite sure if I should just stick with a white background or try to find a interesting place to snap some shots. I guess I need to do some experimenting.
  5. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    effing amazing!
  6. Cheapskate
    13 May 2007
    The trick will be to get the camera to focus on the case, not the stuff in the reflection.
    Don't forget to strip naked for the photoshoot.:thumb:
  7. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Thanks!
    :worried: There are things that cannot be unseen.
  8. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I finally found a place I like to take some pictures. It's only accessible by bicycle so I think Monday I'll rope my little bro into going with me to help carry stuff. :thumb:
  9. Nexxo
    23 Oct 2001
    Just a table with a plain white background will do...
  10. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    It's not as bad as it sounds. There's bike path by my house and the spot is only a few minutes away.
    I'll probably take some normal photos too. I just have not had much luck taking pictures inside my house so I figured I could have some fun with it.
  11. Monsieur R.
    1 Dec 2011
    I can't wait for the final shot :)
    But, I have to confess, I'm a little bit confuse about your CPU cooler disposition : I think the end of the heat pipe should not face down. :nono: I found nothing on this on Thermalright's technical page but both Scythe and Noctua recomand to not do so :
    :confused:
  12. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Wow I completely overlooked that.:duh: I know it won't fit rotated 180 deg which is why I put it in that way. But I bet it will be alright if I put the heatpipes toward the ram. I'll try that out and see what happens. Thanks!
  13. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    This is it, it's finally done!
    Then I did some experimenting with low light shots.
    Thanks for reading!
  14. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    At the request of someone else I took some pictures of it in use. I already returned the dslr I borrowed so sorry about the crappy pictures. The lighting in my room is horrible too :p.
    Load temps aren't too bad at all, they seem to be plateauing at ~65-70C.
  15. Attila
    Attila still thinking....
    22 Feb 2008
    It's gorgeous! :clap:
  16. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    No kidding. And nice choice on the X-25m SSD, they are nice and nicely priced still.
  17. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    To hear that from a legend like you is such an honor!
    It was my first SSD many years ago and it's still going strong!
  18. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Wow, I just love the base and feet, and the way all cables are tucked at the back.
    Also, the setting for the shoot is excellent - the contrast of modern/rustic, shiny/textured, and wheel/railroad!
    This build rocks!:rock:
  19. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Well, this is just magical! i have not seen attention to detail like this in a very long time, awesome work! will defiantly look out for you in the future!
  20. Monsieur R.
    1 Dec 2011
    Nice final build ! And I'm happy to see you were able to tilt your CPU cooler by 90° ;) :thumb:
