Scratch Build – In Progress Baby Moon *Complete*
Discussion in 'Project Logs' started by shinji2k, 12 Jul 2013.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow! simply stunning!
  2. KidMod-Southpaw
    28 Sep 2010
    Just. Wow. Yes.
  3. Elladan
    Elladan Minimodder
    17 Mar 2012
    really nice job :thumb:
  4. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Taking some of those shots was interesting. I didn't want to be in any of the reflections so there were a couple times I sat the camera on the ground, set the timer and then jumped into the bushes. :p You can see in my 'in use' pictures that everything in the room is reflected off the sides so I thought it was important to find a good place to take pictures. It took a few days but I'm happy with the railroad bridge I found. :D
    Thanks! I'm already feeling the itch to start on something else!
    Yup, it just fit. I'm not sure how much it helped but it's staying where it is. :p Thanks for your help!
    :rock:
    Glad you like it!
    Thanks!
    To be honest the response I've received is much more than I expected. I'm very grateful for all your kind words, you all are awesome!
  5. Cheapskate
    13 May 2007
    :thumb: I think you know how I feel about this project already.
  6. Evenge
    Evenge Minimodder
    16 Sep 2006
    Awesome work! :)
  7. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    You'll have to forgive me for not posing naked. :p I really appreciate your encouragement along the way!
    Thanks!
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Awesome work, great location for the pictures!
  9. Friction
    Friction What's a Dremel?
    27 Sep 2005
    Am I the only one who has noticed that you have no air flow going on? Everything inside that metal fram is going to cook if you don't add some holes for air to pass through.
  10. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I was a little concerned with that but I've done some extensive testing. It does get warm, but there seems to be enough convection happening between the gaps to keep things in check. I am slightly concerned about the motherboard but the downward fan on the cooler should keep it from getting too hot. As for the SSD, it's a tank. I'm not worried about it. :p. According to my Kill-a-watt it only draws 15W at idle and 50W when loaded. There's not that much heat to get rid of in the first place.
  11. asura
    asura jack of all trades
    22 Apr 2009
    That's no moon; it's a triumph!
    I really love the second low-light shot where it looks almost portal-like.
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    This turned out amazing, :rock: I know I'd be proud of it if I made it. :D:clap:
  13. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I think it took like four different photo shoots to get the lighting right. That's actually my basement :p. I'm really proud of some of those shots.
    That means a lot to me, I love your work!
  14. rrtype
    rrtype What's a Dremel?
    5 Aug 2014
    gorgeous! compliments!
  15. Bad Fenny
    Bad Fenny What's a Dremel?
    20 Aug 2014
    Excellent build . . . you are a true artist when it comes to metal work.
    Cheers
    Fen
  16. amagriva
    amagriva Minimodder
    13 Jun 2009
    Every time I watch your gorgeous job it seems to me like the thing is ready and waiting to run away.
    I don't know if i spoke my mind clearly...
    Whatever...Bravo!
  17. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I get your first post, awesome!
    I always thought I was bad at art :hip:. I must have lucked out this time :D
    I understand and that's a huge compliment in my mind. I don't deserve your kind words :thumb:.
  18. Nexxo
    23 Oct 2001
  19. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Yeah someone at OCN pointed that out to me earlier! I think the other two mods he picked are great, not sure I belong there in the same article :p.
  20. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    Really nice! Please check out my mITX scratchbuild project!
