Case Mod - In Progress Baby Project 2020
Discussion in 'Project Logs' started by Antera23, 25 May 2020.
  1. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hi everyone,
    This year i'm building with Asus and Cooler Master's support .
    The base of the build is a Cooler Master H100 mini case, which will be equipped with water cooling.
    * M/B : Asus Rog Strix Z390i Gaming
    * RAM : GEIL Evo X II 3600 2x8gb
    * Storage : ?
    * CPU cooler: AlphaCool XPX 1U
    * PSU: Cooler Master MWE Gold 650 full modular
    * Reservoir/Pump AlphaCool Eisbecher 150
    * Fittings, hard tubes AlphaCool.
    Introduction to the build:
    The build consists of 3 main pieces. The lower base is an egzota wooden frame, inside this is the
    240mm cooler on top of which is the PSU as the middle layer. The fan of the PSU fit on the radiator and
    is accompanied with another 120mm fan. At the top is the H100 case, for which I built a custom
    aluminum bottom tray to adat to the middle and lower layer.
    The H100 is a short case, so I expanded it to fit an Asus ROG Strix 1660Ti card (+70mm)
    The rest of the liquid cooling system will be built using Bitspower components.
    The CPU and the GPU will be on the same loop.
    Ther won’t be a separate pump, all will be circulated by the CoolerMaster AIO (modified to fit G1/4
    connector). Tube-wise I’ll go acrylic or metal.
    The factory black side panel will be replaced with glass pane, while on the other side (+70mm extension)
    it will house glass or a wooden element.
    At the front, the factory fan will be replaced with an ARGB 200mm fan.
    Used materials:
    - Egzota wood, Ovangkol
    - Aluminum
    - Stainless steel anchor points
    I will upload photos later in to the blog.
    Google pic's:
    https://drive.google.com/drive/folders/1kgmZ53WrXcumEoH5Uqb4Mq8lg2nTNDhk?usp=sharing
  2. MADPC
    MADPC Minimodder
    10 May 2020
    baby is a nice name to give to this mod..
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    There's some real modding going on here folks! love what i see so far :rock:
  4. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Cooler Master H100.
    Baby size case.
  5. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Thank you bro !
    I hope the end result will be good too.
  6. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hello,
    Construction continues, with the help of new sponsors.
    Thank you Alphacool, Geil!
    New pic's google drive map.
