Case Mod - In Progress Back to Nature - Ivy [completed]
Discussion in 'Project Logs' started by MegaSkot, 15 Feb 2016.
  1. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Back to Nature - Ivy.
    Master Case 5 will represent the tree stump wrapped in ivy. Everything would be done in airbrush technique. The outside will look like an imitation of the tree bark, while on the inside all will be in colors of the wood.
    On the front side will be a tank with air bubbles and the green LED will illuminate engraved "MasterCase 5".
    On the left side of the chassis will also be a tank, but much bigger, with air bubbles and plexiglass ivy leaves also illuminated with green LED, creating a nice effect.
    Moss will be on the front of the chassis, as well as on the stand, that will be an imitation of the earth around the roots.
    The liquid in the reservoir will also be green (EVO UV Lime GREEN).
  2. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Big thanks to Avexir!
  3. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Using styrodur(styrofoam) and soldering I'll do an imitation of tree bark.
  4. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Gigabyte GTX 970 G1 Gaming OC:
  5. MegaSkot
    MegaSkot Member
    12 Feb 2015
  6. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Airbrush...
  7. storm-83
    storm-83 Member
    7 Nov 2014
    wow - mind blown!
    that brushwork *jawdrop*
  8. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Thanks.
    Some more...
  9. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    Very nice work. Is the wood grain just painted on, or were you using something for a pattern?
  10. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Just painted. :)
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I like the paintjob :)
    Can you explain a bit how you did it?
  12. MegaSkot
    MegaSkot Member
    12 Feb 2015
    I'll make a photo tutorial. ;)
  13. MegaSkot
    MegaSkot Member
    12 Feb 2015
  14. MegaSkot
    MegaSkot Member
    12 Feb 2015
  15. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Creative Sound Blaster Z - airbrush.
  16. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Avexir Blitz series airbrush:
  17. neSSa
    neSSa Active Member
    11 Aug 2014
    Good paint job!
  18. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Thank you my friend.
    Daylight pics:
  19. MegaSkot
    MegaSkot Member
    12 Feb 2015
  20. MegaSkot
    MegaSkot Member
    12 Feb 2015
    Thanks to EK Water Blocks for sponsorship!!!
