Windows Backing up DVDs
Discussion in 'Software' started by Anator, 8 Dec 2005.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    Ok,
    Basically I have a couple of films and tv episodes i would like to have a copy of on my pc, never tried anything like this before so dont really know whats best to use. Im trying the divx converter atm but it doesn't give me the option to pick just 1 chapter off a dvd or give me any flexability on the size of the output.
    Can anyone suggest any bits of software I could use to do this?
    Cheers.
  2. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    DVD Decrypter.
  3. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    doom9.org is the best source for this type of info.
    I think there is(or was) a guide to backing up movies on here somewhere.
    Thought it was a sticky too.
    Search here for DVD backup and see what you come up with.
    There are plenty of guides around. You must improve your google-fu.
  4. ch424
    ch424 Design Warrior
    26 May 2004
    If you just want to "back up" your DVDs, use DVDshrink and some CD writing software... or virtualCD software.
    ch424
  5. Anator
    26 Feb 2004
    Thanks guys, decrypted an episode of 24 and currently coverting it to avi using autogk, although a single episode has taken over an hour so far and I have no idea how much is remaining. Must say im surprised it takes this long.
