Peripherals Backlit Keyboard
Discussion in 'Hardware' started by shaleenh, 25 Nov 2009.
  1. shaleenh
    shaleenh What's a Dremel?
    31 Jul 2009
    Hi,
    Could someone please recommend me a good backlit/illuminated keyboard? I'd prefer one with low, laptop-like keys for comfortable typing. Budget would be ~40 quid, though cheaper is definitely preferred. USB ports in the keyboard are a plus, though I don't care either way about macro keys. Corded preferred, though I don't mind cordless.
    A huge plus would be a proper touchpad built in, though I doubt if there are any such keyboards available.
    Thanks.
  2. steleet
    steleet Did he death?
    22 Oct 2009
    I don't know what the hell a quid is but I would recomend a Logitech G13 or a G15 if you want to get something really nice.
    The keyboard itself is more like a standard desktop size/shape. But it is corded USB. Along with two USB ports on the keyboard itself. Also it has macro keys. Oh yea, backlit as well :p
  3. GoodBytes
    20 Jan 2007
    Logitech Illuminated keyboard. Great keyboard. I have it, and I love. It really adds professionalism to a desk. White backlit LED is true white, if you wonder.
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    What GoodBytes said.
  5. Hamfunk
    Hamfunk I AM KROGAN!
    10 Nov 2009
    Saitek Eclipse II (http://www.ebuyer.com/product/118274)
    Thats the one i have, and you have a choice of 3 backlight colours built in (Red, blue and purple?!). It's usb corded, the palm rest is remove-able and you can control the brightness of the backlight.
    I would definitely recommend this (the logitech G15 looks hideous!!)
  6. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    ooo i like that logitech board
  7. craigp84
    craigp84 What's a Dremel?
    28 Oct 2009
    Logitech G15
    I have the logitech G15 (v2 version which is not as wide so it fits in a normal keyboard drawer under a desk, unlike the v1) which i bought earlier this year.
    It's a good keyboard, quality is hard to find faults with, and the LCD screen with their software to drive it, is actually pretty useful (CPU / Memory monitor, RSS feed reader are my favourites).
    However, for all there is to recommend it, the price is not one of them. It is not worth the £70 or £80 i spent on it. If you can find this keyboard for ~£45 mark, i whole heartedly recommend it.
  8. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    i have the Saitek eclipse II and its fantastic. theres nothing else to say.
  9. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    I too love my Saitek Eclipse II.
  10. smc8788
    smc8788 Multimodder
    23 Apr 2009
    The Saitek doesn't have low profile keys.
    +1 for the Logitech Illuminated by the way, it's what I'm using to type this post. The only other decent keyboard I can think of that's both backlit and has low profile keys is the Razer Lycosa.
  11. andrew8200m
    andrew8200m Modder
    4 May 2009
    +1 for the logitech. Its the only one your likely to find in budget. The microsoft x6 (i think thats the number) has sort of low profile keys and is reasonable if you want something to look a little "different"
    Andy
  12. Carper
    Carper Guru
    19 Aug 2009
    have you guys with the logitech illuminated keyboard made the legs bigger so it stands up more?
  13. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I haven't seen the need to really, I found it's at a perfect angle as it is.
  14. shaleenh
    31 Jul 2009
    Thanks for all the advice people. I've decided to go with the majority, and get the Illuminated keyboard, but will be waiting till the 12th of Dec, when Logitech will be having 25% off everything. :)
  15. Mr. Ducky
    Mr. Ducky What's a Dremel?
    15 Aug 2009
    I've had the logitech illuminated one for just under a year, you won't regret it, fantastic keyboard :)
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    It looks really really good
  17. Kronos
    Kronos Multimodder
    6 Nov 2009
    I got the Saitek Eclipse 111, great board.
  18. Carper
    Carper Guru
    19 Aug 2009
    wheres the 25% off sale?
  19. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    +1 on the Logitech Illuminated. Personally i have a G15 V1 but if i liked low-profile laptop keys i'd probably get the illuminated.
  20. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    http://www.maplin.co.uk/Module.aspx?ModuleNo=36401
    Thought I'd throw something a little different into the mix.
    I use to have that keyboard, but after a few years of heavy use the letters start rubbing off.
    And I've litterally just discovered they do a full size one as well so I'm off to order it!
    :D
