Backup program
Discussion in 'Software' started by 24giovanni24, 23 Mar 2008.
  1. 24giovanni24
    24giovanni24 What's a Dremel?
    21 Mar 2008
    I am looking for a free program that will allow me to zip a file and then burn it to cd-r disc. Can someone recommend a good, dependable program please? I appreciate any positive help.
    TIA
  2. Glider
    Glider /dev/null
    2 Aug 2005
    A regular batch script maybe?
  3. 24giovanni24
    21 Mar 2008
    Can you provide me with one? I have nero if that's any help?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Single files? Just get 7-Zip or Zip Genius. You can use Win's built-in burner program or Nero to transfer to CD.
  5. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Right, like cpemma said. For simple files programs like 7-zip and Jzip work just fine. If you want to regularly backup certain folders then Cobian Backup is pretty good.
  6. 24giovanni24
    21 Mar 2008
    Is anyone familiar with filefort with express burn plus? If so, does it always stay a free program?
  7. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    As suggested above... use 7-Zip to compress the file, then one or other of the many FREE CD/DVD burning programs available...
    i.e. CD Burner XP (used it in the past meself), Burn4Free, BurnAware, Deep Burner, Final Burner etc etc :idea:
  8. 24giovanni24
    21 Mar 2008
    Nope, filefort with express burn plus are the better option. All I have to do is set it and forget it as long as I put a cd-r in the drive.
  9. Hazardous
    21 Jan 2004
    Fine.
    I assume, therefore, you found the answer to your question...
    For the benefit of anyone else looking for a similar solution... would you care to share your findings :idea:
  10. 24giovanni24
    21 Mar 2008
    filefort is free with express burn plus is a pay s/w but they have a free version but doesn't automate everything.
  11. graysky
    graysky What's a Dremel?
    25 Mar 2008
    Why not create a backup set using winrar then burn it to disc. Follow the instructions here. Be sure you make parity sets so in case one of your files goes bad, you'll be able to replace it.
    Here is my backup.bat
    Code:
    path="C:\Program Files(x86)\WinRAR"
    rar a -m3 -md4096 -v100m -rv40p -msjpg;mp3;tif;avi;zip;rar;gpg;jpg -x*.m2t @list.txt
    That list.txt is a list of the dirs and files I want to backup:
    Code:
    e:\Documents and Settings\user1
    c:\Documents and Settings\user1\Desktop
    c:\Documents and Settings\user1\Start Menu
    c:\Documents and Settings\user1\Application Data\
    e:\Documents and Settings\user2
    c:\Documents and Settings\user2\Desktop
    c:\Documents and Settings\user2\Start Menu
    c:\Documents and Settings\user2\Application Data\
    c:\*.conf
    c:\*.cfg
    c:\*.bat
    c:\cook*.*
    You're left with the files and parity sets you can simply burn to DVD:[​IMG]
