Windows Backup - Stuck continuous backup
Discussion in 'Software' started by pullet_surprise, 7 May 2013.
  1. pullet_surprise
    pullet_surprise What's a Dremel?
    14 Sep 2009
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Reboot the machine?
  3. GoodBytes
    20 Jan 2007
    I have a more concerning question:
    Why do you have this bar that is not suppose to be there... it's a tool bars that tried to be installed.
    Oh and to answer your question: Make sure that the Windows Backup service is running. (The name might be different, I am going from memory, I use Win8, sorry.. but go through the services list, and make sure that anything that is related to shadow copy, and backup is running). If they are, restart your computer and see if it works as suggested.
  4. pullet_surprise
    14 Sep 2009
    Restarted several times but it just continues to backup?
    I will try to kill the service when I workout the servicename. I even deleted the backup image file
  5. pullet_surprise
    14 Sep 2009
  6. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I've just checked several machines here in the office. Pretty sure that little bar is standard.
  7. GoodBytes
    20 Jan 2007
    No it's not.
    No bars.
    I never saw that bar on any of my computers.
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I don't have the bar on my computers or any of my ones here in the office.
  9. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Do a malware clean, than an SFC /Scannow and post the results
  10. pullet_surprise
    14 Sep 2009
    Log to big to post.
    http://img24.imageshack.us/img24/715/15293138.jpg
    Driving me bloody nuts. Not sure what these acronis references are, took it off a year ago?
    I have stopped all related backup services, but it still runs.
  11. badders
    4 Dec 2007
    Figured it out - if you hit Alt, the Menu bar drops down from that bar. If you then go to View - Toolbars -Lock the Toolbars, the line disappears.
    Our machines here must be set up to not lock the toolbars by default.
  12. GoodBytes
    20 Jan 2007
    Hmm interesting, I pop Win7 HDD, and I don't have this option.
    Like under View, Control Panel for any other folder location, I don't have anything called "toolbar". I only have Status Bar,
  13. pullet_surprise
    14 Sep 2009
    Okay. I deleted every reference to acronis using the clean up tool. As if by magic my backup settings came back. The task bar still shows as continuously backing up. Even though the windows backup service is stopped.
