Motherboards bad check sum
Discussion in 'Hardware' started by heir flick, 30 Sep 2009.
  1. heir flick
    heir flick Minimodder
    2 Feb 2007
    a few times on boot up i have a bad check sum error and the bios has reset to default and the time and date has changed, im thinking the motherboard battery is on the way out, anyone have any other idea
  2. butter100fly
    butter100fly Rebelstar Raider
    16 Sep 2009
    I'm not sure a flat battery would give you a checksum error - its a bios error right?
    What is the MOBO and what date does the BIOS default to?
  3. heir flick
    2 Feb 2007
    its a asus p5e, had it for about two years with no problems untill now, cant remember the date it reset itself to
  4. capnPedro
    11 Apr 2007
    Sounds like the battery (CR2032) to me.
  5. heir flick
    2 Feb 2007
    will give the battery a go, cheap enough
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The battery powers the CMOS (where the BIOS settings and info about the hardware is stored). If it fails, the CMOS will lose it's info, and the integrity check won't succeed (wrong checksum).
