I was trawling the DICE forums looking for info about server crashes, and found a couple of useful links to other fixes. Disconnects from server / CTD Kit select freeze List of stuff DICE knows is broken Saitek x52 fix That's all I've got. Chuck some my way via this thread if you find them. Did they fix Dx9 yet?
I was wondering why I kept getting disconnected last night, I forgot I had enabled UPnP for MW2 Oddly though I don't have a BT Home Hub, but an O2 Wireless Box :/
kit selection freeze fix works perfectly. they should have used XML instead of INI's. i've got setup through 2 routers, one of my own and another the whole house's. looks like i'll have to disable it. how do i disable it on O2 wireless box 2? the interface is so clunky.
In the menu go to Toolbox, then Game and Application Sharing, then you have to click 'Configure' in the top right and uncheck the box next to 'Use UPnP' and click 'Apply'.
Oh I use this configuration widget. Really handy if you run a last gen card and switch between Dx9 and 11 often hoping the other mode won't still suck. Lets you set FoV, detail settings and stuff as well. http://ohlawl.com/liseda.html
I died a little inside when I saw everything was already at the minimum settings in my config... I want this game to run better. Screw the shìtty 55fps framerate, I want more, MOAR !!!
Ooooh check you out with your 55fps. :'/ I can get something like that on DX9, although it breaks loads of things, and DX11 just takes a huge dump on my graphics card.
Great work, i run a domain type network at home and there are all manner of issues sometimes with relation to game settings and saves etc... will let you know how this fix goes
"Floating window" after destroying wall. Also, there are textures still visible from the grenade explosion on the wall: Unlikely to be fixed. What the ****?!
