Bad Company 2 - suggestions thread
Discussion in 'Game Server' started by Rogan, 15 Feb 2010.
  1. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    When does the CustomPC BC2 server get busy? I've checked the server a few times over the last couple of evenings and its never had anyone playing.
  2. C4vey
    C4vey What's a Dremel?
    8 Feb 2010
    You have to join before it fills up. Usually once it gets 6 or 8 people on, the matchmaking does the rest.
  3. Ph4ZeD
    22 Jul 2009
    To be fair I didn't play BC2 last night so I don't know if it filled up last night. I'll definitely be joining tonight though.
  4. Tuned#F_A_F
    Tuned#F_A_F What's a Dremel?
    18 Mar 2010
    Devil's Advocate: Could we switch the server to Hardcore mode? I'm only a lowly level 4, and using starter guns against level 30+ players is impossible to get a kill on Softcore. Just played a good ninety minutes Hardcore and even the Recon starter rifle is deadly!
    It's just a thought, but I know that a lot of players are finding the game a bit too hard on softcore, and Hardcore mode is much easier to get to grips with....and fun :)
  5. Rogan
    Rogan Not really a
    6 Oct 2003
    ok, hardcore on
  6. Rat1sully
    Rat1sully At Least Skt478 Never Broke
    29 Apr 2009
    be warned a lot of newfags will not like this rogz
  7. Rogan
    Rogan Not really a
    6 Oct 2003
    Well it's not really being used is it, so might as well.
  8. Rat1sully
    29 Apr 2009
    actually I go away for a week due to surgery and come back to a dead server, wasn't impressed.
    biggest complaint off my mats who've just got is is lack of HUD surprisingly:idea:
  9. The Rouza
    The Rouza Run from the Sandvich!
    21 Feb 2010
    hardcore... very bad....
  10. wyx087
    wyx087 Multimodder
    15 Aug 2007
    lack of spotting, no indication of where your teammates are? hardcore is not teamwork friendly at all! defeats core gameplay elements.
    the starting recon sniper rifle is the easiest to get hang of, it's same as all other bolt-action rifles, where 1 shot to the head kills. it's very straight forward, really don't see any problem with this.
    all the best guns are at the start of each class: XM8 for assault, SCAR-L for engineer, SAW or type-88 for medic and M24 (first) for recon. it's just learning to use them effectively is the key. burst fire, spot, working with squads, and sport more.
  11. Tuned#F_A_F
    18 Mar 2010
    ....would be great if you could kill an enemy using less than a clip of ammunition.
  12. wyx087
    wyx087 Multimodder
    15 Aug 2007
    can and have in normal modes, i only play normal modes with kill cam and spotting. XM8 burst fire is more than enough for 2 people, i have used M14 with magnum ammo to take out 2 person one clip, also SCAR-L short-ish range taken out 2 people easily. don't need to mention LMG it's got huge clip. don't forget to pull out pistol often, it's there for a reason.
    also, know your range, don't try to snipe across the map if you know you can't hit them. spot and run for cover.
    give M14 a try, i am starting to love this gun. with magnum ammo it's a 2 shot kil close range, 3 shot kill long range gun. can be really accurate or can fire the whole clip really quickly for a 2 shot kill close range no-ADS.
  13. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Seriously, try the AN-94 w/ red dot and magnum ammo, then complain people have too much health. But most other rifles like the M416 usually only take half a clip of burst fire. Just make sure to use magnum ammo (when you get it) instead of the marksman specialisation since you're not (or shouldn't be) firing full auto.
    Hardcore was great when I was a low rank and only had access to the crappy guns and no scopes/specialisations, but it makes the gameplay much more 1-dimensional and removes one of the main things that was good about the game - teamwork. Not to mention the fact that hardcore servers are usually filled with snipers toasting marshmallows on a remote grassy knoll.
  14. Tuned#F_A_F
    18 Mar 2010
    I'm starting to see a trend here. It's easy to forget that lower level players don't have access to the kit that makes the game easier, as higher level players have. I can understand having equipment that makes the game even more enjoyable, but when you're relying on upgrades as much as the above quotes then it needs serious consideration if softcore is worth playing at all.
    I'm used to working with my clanmates to win, so spotting is not an issue for me and I don't really miss having radar dots. What is an issue is being able to play on a level playing field with other higher level players. It's a great concern to me that enjoying softcore mode is so highly dependant on what you're unlocked....
  15. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Don't get me wrong, you don't need magnum ammo to do well, it just helps a lot (adds 25% damage).
    The class unlocks were one of the main reasons I didn't like the game to start off with. I mean, what use is the medic kit without health packs or a defibrillator? That means I have to play as a medic for several games while my squad mates are complaining because I'm not giving them health packs or reviving them. I'll never understand why they made that decision.
    For everything else it doesn't help too much, but the game does become more enjoyable when you unlock everything. Being able to plant tracer darts on vehicles, laying some AT mines in front of a tank, or equipping the recon class with a G3 and the explosive upgrades and plastering the M-COM stations in C4 is great fun.
  16. Hayze
    Hayze Wo|F Like Me
    11 Mar 2010
    POST Cheesecake
    games ridiculous in that sense
  17. Hayze
    Hayze Wo|F Like Me
    11 Mar 2010
    who edited F t w to say cheesecake? o_O
  18. Rat1sully
    29 Apr 2009
    you know there is only 1 gun in the game that takes clips the rest take mags
  19. wyx087
    wyx087 Multimodder
    15 Aug 2007
    magnum ammo isn't necessary, i usually use the armour perk or auto-spotting sniper scope as all the guns are already powerful enough. sure they aren't CoD's level of powerful, but that's where spotting comes in, spot while shooting will allow your teammates to help you to take down the enemy. team work! don't just relay on voice chat with clan mates, relay on the in-game communication.
    AT mines are the best equipment! people usually don't specifically look for them, and 3 in a line will kill any light tank, 4 in a line for heavy tanks. they also don't disappear when you die (unlike C4) so it's run-like-crazy-planting-mine at start of each match.
  20. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I've never bothered with that. As far as I can tell it doesn't even do anything, so I still have to spot enemies manually.
