Scratch Build – In Progress BaDassumption - Photo Shoot...
Discussion in 'Project Logs' started by dutchcedar, 8 May 2006.
  1. DougEdey
    5 Jul 2005
    Any chance of a WMV/AVI version for us unfortunates without Javascript/Flash at work?
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Here you go.
  3. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    I can post the original MJPG .avi from my camera when I get home, if you still need it.
  4. elliod
    elliod What's a Dremel?
    1 Oct 2006
    MY god :jawdrop: this project is looking better by the day(week)awesome work man you truly are an inspiration too the modding community.
    keep up the good work :clap:
  5. DougEdey
    5 Jul 2005
    Its alright, am at home now :p
    But is the rate of the LEDs going to change with the amount of activity? I.e. with the frequency of pin 39?
  6. GT40_GearHead
    GT40_GearHead What's a Dremel?
    22 Jul 2006
    any new pics :D
  7. Techx
    Techx What's a Dremel?
    9 May 2004
    this is the first time i'm seeing this mod, INCREDIBLE... i love the chrome and all the other parts, i'm impressed
  8. Starbuck3733T
    16 Sep 2002
    Yes, it does go faster depending on the amount of activity. what you saw in the video is the "maximum" rate which is controlled by a switch on the backside of the PCB. Press and hold it to toggle speed up/down and then just tap it to make it go faster or slower.
    The whole thing works on a principle of "minimum on" time. the LED pattern will be turned on if the controller detects activity, but will not be turned back off if the next activity-sample does not detect activity. It stays on for a minum amount of a time (a 16-bit number that's tied to the 16-bit onboard counter.). In essence, if there's not enough activity to keep it going constantly (time between actives > minimum on time) then you'll see the led go out, then the next one come the next time the controller sees activity.
    Pin 39 is not used - the controller is universal. Feed it a current-limited 5V input into the optoisolator, and it does it's thing. Dutch is using SATA drives so I'm banging together a piece of software that watches the windows performance counters and the manipulates the RTS/DTR lines ona serial port to mimic the kind of signal you'd normally see coming out of an HDD activity line on your mobo or PATA pin 39.
    And yes, darnit, I still work on goliath sometimes.
  9. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    ^^^ Starbuck, I lost ya right after, "yes, it does go"... :D
    Rattlecan Paint Test...
    You might remember there were some "extra" pieces of sheetmetal made up, just in case something got screwed up... well, these are spare halves for the PSU pod... I'm playing with ideas for the color(s)...
    Etching primer...
    HOK white base coat...
    HOK Snowhite pearl...
    HOK Tangelo pearl...
    This one was done by taping out the graphics... gotta smooth those curves better...
    This one is simpler to tape out, but I pinstriped it with OneShot purple, using a 00 Mack brush... my stripin' skeels just ain't what they need to be, but I'm likin' these colors...
    Our son likes the first one, wife likes the second, I wanna do something in between... :hip:
  10. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    That orange looks killer. I agree that Something inbetween would definately look good, t hat purple pinstripe really adds something extra to it that you don't see everyday.
  11. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    agreed the purple stripe looks great
  12. customh
    customh conflagration.
    22 Oct 2005
    sweetness, i like both, dont know what to tell ya otherwise
  13. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    i have to say the orange looks great, but what about other colours? a mod this large is obviously driven mostly by personal preference... have you thought about any other colours dutchcedar? :D
  14. elliod
    1 Oct 2006
    great coluors man the stripe really add something extra .
    keep up the good work.
  15. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Orange, that is da shiznits! :hehe:
    Seriously though, It's good to see you are progressing with the mod again. I hope to see much more inspiring stuff from you before this is over :thumb:
    Janne
  16. midnightoil
    midnightoil What's a Dremel?
    28 Sep 2005
    Would be cool to see that combo with a Neon blue replacing the purple just my 2 cents... :rolleyes:
  17. mattthegamer463
    26 Nov 2004
    That activity light thing is insane! Is there schematics/guide to making one of those? I totally need one.
  18. dutchcedar
    24 Oct 2004
    Bingo... I think we've got it!!!
    This will make the bezels Tangelo pearl and much of the pods bodies pearl white... use your imagination... there would end up being sixteen of these scallops altogether... :worried:
    Taped off with the edges fogged with pearl magenta...
    Sprayed over with Tangelo and dusted again over the top with magenta at the edges again...
    Quick shot of clear...
    Keep in mind, I'm just experimentin'... only spent about an hour on this, so yeah, there's a flaw or two... :hip:
  19. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
  20. ctrl_alt_del
    ctrl_alt_del What's a Dremel?
    25 Feb 2005
    Flaw? I couldn't paint like that in a million years!!
    Great Job!
