Scratch Build – In Progress BaDassumption - Photo Shoot...
Discussion in 'Project Logs' started by dutchcedar, 8 May 2006.
  1. widmod
    widmod Minimodder
    9 Oct 2006
    ok I see everything is well planed. :idea:
    I just taugh that some parts like des res and de pump are allready installed permanently :dremel:
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    hey dutch, can you please tell which brand router tip you're using here ?
    Thank you! :hip:
  3. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    ^^^ Hey Bill...
    Its a carbide tipped Makita 1/2" round-over bit with a 1/2" shaft and a guide bearing.
    Most of the router bits I used are Makita with carbide cutting edges.
  4. pedrofilho
    pedrofilho What's a Dremel?
    4 Apr 2007
    Very nice mod, keep going.
    Congrats,
    Pedro Torres.
  5. Abom
    Abom What's a Dremel?
    15 Jan 2004
    please update my modding crack dutch!
  6. widmod
    widmod Minimodder
    9 Oct 2006
    your mod had been fallen from the edge of the forums :wallbash:
    don't tell us your aren't using this awsome system allready! :jawdrop:
    did you buy the monitors?
    please UPDATE :clap:
  7. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    That's some great work ceder, came out great, now put it all together and get it running.
  8. dutchcedar
    24 Oct 2004
    "My space" isn't big enough, so its on to building a new office while waiting for Intel's Penryn processors and other sponsored items...
    First, we cleared some space...
    Moved some dirt...
    Framed up some retaining wall forms...
    Poured some concrete...
    And started building the home for BaDassumption...
    This should be done pretty soon and then I'll get back to buildin' the rig... :thumb:
    This is her room...
    So that's what I've been up to. :hip:
  9. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    ROFL :D - best excuse EVER for not updating a 'log' in a while.... looks like you have been chopping them down and building a room with them (excuse the awful pun but i couldnt help myself!).
  10. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    So does that make you the first to scratch build a room to put his modded PC case in? I was wondering why they used 2x4's rather then plywood sheets for the cement wall forms though.
  11. Cyprio
    2 May 2006
    Cos he lives in a forest???? :)
  12. dutchcedar
    24 Oct 2004
    We use 2x6's because we can reuse them for framing afterwards. :hip:
  13. Cheapskate
    13 May 2007
    2x6 plus 18" framing? That's free king solid! Down here everything is framed at 26". Here you don't need a window to get out of a burning house, just a football helmet.:D
    Do the Pillars mean you're adding a deck on the 2nd floor?
  14. ComputerKing
    8 Sep 2006
    WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    DAMIT I want to live on that space only of the rest of my life :( I want one
    damit
    you did all kickasss things... ;) ****ing hot pc... now the space ... well done..
    lucky! :D good luck
  15. Stonewall78
    21 Oct 2005
    Makes sense but I wouldn't want concrete all over my wood. 26" on center? man everything around here is 16". I can't even imagine trying to find studs on 26".
  16. customh
    customh conflagration.
    22 Oct 2005
    dutch, yours is framed 18 on center, right?
  17. dutchcedar
    24 Oct 2004
    ^^^ The walls and floor joists are framed at 16" centers, the roof trusses are at 24" centers.
    We have to design for fairly heavy snow loads and seismic forces around here. :hip:
  18. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Dutch, I love your mod! It brings back memories of working on Big Daddy Roth's plastic models with my dad. (Showing my age a bit there.) Well done!
  19. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    Was wondering why this log went into lumber ... oops i meant limbo ...
    Im thinking of adding onto this house im in ... might just dig out a cellar ....
    make it sounds proof ..
    put in some "toys" ....
    ok nuff said ..
    Looks great man!
  20. widmod
    widmod Minimodder
    9 Oct 2006
    UPDATE :sigh:
