Storage Ballooning SSD install size
Discussion in 'Hardware' started by gilljoy, 23 May 2011.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    When I first installed my SSD the windows install size was just over 10gb with hibernation removed and pagefile reduced in size.
    Since using the computer for a fortnight its doubled in size to around about 20gb in size, Now Some of that will be from installing office 2007 but theres no way that office is nearly 10gb in size.
    Any idea why this is happening? Could it be to do with windows update left over files? Everything else is installed on my spin point
  2. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Google Windirstat
    It'll give you a breakdown o everything on the drive.
  3. Subv3rse
    Subv3rse What's a Dremel?
    22 May 2011
    Almost definitely to do with windows updates. This would include office updates etc also.
    Temp files may also be a factor, check the windows temp folder (Disclaimer: if you don't know what you are doing, don't fiddle with it as you "can" cause issues).
    Further, pre-fetching, unless turned off by the SSD driver suite, will be filling up, and shadow copy will, again if not turned off by the SSD drivers, be creating system image restore points regularly.
    Using something like CCleaner and optimizing your Windows config for SSD usage is something worth looking at.
    Regards,
    Subv3rse
  4. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    used that before,
    looks like the users folder has doubled to two gigs, n theres a huge file inside the windows folder winsxs which is 6 gigs :O
  5. Big Elf
    23 Apr 2009
  6. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    How big is the ssd you got? I've used 40gb or so of 75 and only really have my main programs on there.
  7. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    got a 64gb M4. Yea its sitting at about 19gb atm. Bloody winsxs is 6gb :O
    Plently of space just dont wana put two much on it and degrade performance
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Don't be fooled by the size of WinSXS, Windows uses a bunch of symlinks in there to point programs towards the correct version of the DLL that's needed. It's not as big as you think it is ;)
  9. Droih
    Droih Your too close if you can read this
    17 May 2010
    If I remember this right, an SSD will do optimal with 25% free space - and the trick is to shrink your partition by 25%(assuming you partitioned 100%) then you can be sure that those 25% are not breached and you don't have to think about it really :clap:
  10. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    I think I'll do that when I'm doing my next reinstall, means I wont have to worry :D
  11. Deders
    Deders Modder
    14 Nov 2010
    Look for the actual size on disk figure, some things are automatically compressed and others are shortcuts like mentioned above.
    Also there are 2 temp folders, one within the hidden appdata/local folder, the other in the windows folder.
  12. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    How does that work? I assumed that if the partition didn't cover a certain portion of the drive (using your example, 25% of the drive) that area is inaccessible to the OS, and therefore it isn't 'free space' for the drive to use in load-levelling etc etc. I would definitely partition 100% and just keep an occasional eye on whether it's filling up - My Computer shows it as a loading bar, it's not exactly taxing.
  13. Madness_3d
    26 Apr 2009
    if it's any consolation, my winsxs is over 9000!!!! Mb...
