Graphics Banding in Doom 3...
Discussion in 'Hardware' started by Tim S, 8 Mar 2005.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-16
    Guest-16 Guest
    To be honest i cant see what you're on about, that pic looks normal on this crappy uni monitor.
  3. Tim S
    Tim S OG
    8 Nov 2001
    turn the brightness up and you will see what I mean... down the tunnel there are 'bands' of different lighting exposure, rather than a single, smooth transition from dark to light. It is more noticeable in game, though.
  4. Mister_Tad
    27 Dec 2002
    not noticed it before, but ill fire it up and have a gander
  5. Tim S
    Tim S OG
    8 Nov 2001
    The gamma in Doom 3 is higher than on the desktop, that's the reason why it isn't easy to make out from a screen shot.
  6. Mister_Tad
    27 Dec 2002
    cant say that i can see it
    where exactly is that screenshot?
  7. Tim S
    Tim S OG
    8 Nov 2001
  8. Mister_Tad
    27 Dec 2002
    just found where you mean
    i get the same :/
  9. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    well thats not kool, does it do this is other games...(i polay mmorpgs so the image quality doesnt really matter)
  10. Tim S
    Tim S OG
    8 Nov 2001
    I've seen it on the water in Half-Life 2, but apart from that.. I've not seen it elsewhere.
  11. Guest-16
    Guest-16 Guest
    I see it now im on a TFT, but CRT you cant.
    I think it's because the engine is trying to emulate some sort of smoke, but gradient it with AF and each of the gradients are sub-gradients to fade it out from dark to light brown, but something has gone wrong in the colour that the bands looks either too green or too orange when placed next to each other. Tried other AF settings? Maybe it's just nvidias algorithums?
  12. Mister_Tad
    27 Dec 2002
    can see it on my CRT :confused:
  13. Tim S
    Tim S OG
    8 Nov 2001
    me too, I don't own a TFT - the quality just doesn't compare to a CRT IMHO :)
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
  15. Tim S
    Tim S OG
    8 Nov 2001
    It's interesting, very interesting... this comes with exploring the game a little more and changing the section I use for manual run throughs. I have to say that I didn't particularly notice it when I was running an X800 XL, but I'm installing one again in a sec so I'll have another look. :)
  16. Firehed
    15 Feb 2004
    Did it do it before the latest drivers though?
    I was reading thru the beta drivers list of things (not sure if you mean latest beta or release) and I seem to remember it mentioning quite a few things regarding 6800-series IQ
    Of course, I'd like to see you draw something with a smoother transition.
    bigz you have too many cards... I don't care whether or not they're samples.
  17. Tim S
    Tim S OG
    8 Nov 2001
    I forgot to state that I was using the latest ForceWare drivers from NZone: release 71.84.
    I didn't notice this when I played Doom 3 through, but then, I wasn't really taking in graphical glitches back then - from Leeum's screenshot, it looks to be across all video cards.
  18. Mister_Tad
    27 Dec 2002
    I didn't notice it the first time I played the game either.
    Seeing as it is a part where there is little other to do than just look around, and I usually pick up on things like that, I don't *think* it was there the first time around.
  19. Leeum
    16 Feb 2004
    Might be worth rolling back to older drivers if you can find any. Then we'd be able to see if this is a driver glitch or not.
  20. Malvolio
    Malvolio .
    14 Dec 2003
    I don't know what you're all on about :eyebrow: I've seen this same exact effect on every 3d game I've ever played, no matter what the video card was. It's simple: what you are seeing is a transition, and can't be avoided untill FSAA evolves well beyond what we have now.
    Oh, here's a question though: why is it that I can only play Doom 3 at more than 10fps when it's on the absolute minimal settings? I figured that a 2ghz AMD system with 512 of 3200 dual channel and a 9800pro would be able to handle Doom 3 at better resolutions than 640x480 and all the effects turned off...
