Cooling barbed vs. plug-in hose connectors
Discussion in 'Hardware' started by Olly, 27 Mar 2003.
  1. Olly
    Olly What's a Dremel?
    21 Mar 2003
    Hi,
    I'm planning my first water-cooled system, and I'd like
    people's opinions on the best / most reliable connectors to use.
    Do I go for conventional barbs + hose clips, or use one of
    the push-fit systems like they have on Swiftech or
    Aqua-Computer gear (I have horrible visions of them popping
    out & filling my case with water!)
    Cheers,
    Olly:confused:
  2. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    From my little bit of messing with push-fit and standard barb types, the pushfit actually seem stronger to me. I think I'd actually trust them more. Depends on preference, I'd guess. Mines a mix of both. I had one small leak on one of the barb connections, but the push-fit style on my block haven't had a single problem.
  3. Pug
    Pug What's a Heatsink?
    16 May 2002
    I'm with ndtinker on this, however I will add, without prior experience of them (or measuring and marking how much the tube has to go in) it is easier to not push a pipe fully home in a push-fitting than it is on a barb where you can physically see how much it's inserted.
    It's a little like an AGP card where you have to push it it harder than you'd expect but, as ndtinker said, once it's there, it's there (until you decide to release it).
    The choice also depends on the rest of your setup, if you're aiming for high volume flow, the push fit hoses are sometimes less readily available in the larger diameters (although B&Q now have some in their plumbing section for household water pipes :lol:).
  4. adwhitworth
    adwhitworth What's a Dremel?
    12 Mar 2003
  5. Olly
    21 Mar 2003
    That's a great setup adwhitworth - very neat.
    I'm not familiar with your block - what is it and where did you get it?
    Also, which rad are you using and how quiet is the whole system?
    Cheers,
    Olly :D
  6. adwhitworth
    12 Mar 2003
    Olly, Thanks:D
    The block is a Little River White Water Block imported from a guy called Cathar in Australia. He did produce them himself but the demand has been so high as they have been proven to be nearly one of the best blocks in the world, that he simply is not having any spare time so is having them properly made by a company in the US.
    Originally, it came with normal 1/2" barbs but I converted it to match the rest of my pushfit system. The idea behind the block is 1 inlet and 2 outlets which would usually be joined by a y-piece to bring it back to 1 but i decided to make it neater and alter the resevoir.
    I am using the OCPC The Deep Rev. 2 with a 28db, 60cfm 120mm Papst Fan. It is nice and quiet but i've decided to 7v the fan to make it perfect! :D :p :clap: :rock:
  7. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    Sorry to hi-jack for a min....
    Ad,
    Can you tell me what pump you're using as I'm currently looking for something small and decent to fit into my coolermaster as my current enheim 1250 is just TOO much I think....
    Cheers
  8. abombss
    abombss What's a Dremel?
    30 May 2002
    Where did you get the push fit fittings?
  9. Jody Krivohlavek
    Jody Krivohlavek What's a Dremel?
    8 Apr 2003
    My system, which is about 4 years old, uses a combination of barbs and straight acrylic tube. The acrylic tube has no barbs at all... and holds just fine... but I use clear vinyl tubing and it's inner diameter is the same as the outer diameter of the acrylic tube.
    PLUS, my system is purposly LOW PRESSURE. I want the water to cycle slowly to pick up more heat from the copper water blocks and release more in the radiator. So far, this theory works just fine.
    For pictures of my system... see this thread... the 3rd post has pictures of the system the first link in the first post is actually the plans I used to machine the waterblocks I use.
    Enjoy! :thumb:
  10. adwhitworth
    12 Mar 2003
    Jetset, Sorry for the delay. Been really busy.
    The pump is the Hydor L20 (EX700) from Chill-Tek.
    It is slightly better than the 1048.
    I got the pushfit stuff from Technobots.co.uk and RS www.rswww.com
  11. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    in adition to being available in large sizes very easily, a true enthusiast will want to ream his barbs out to a thinner wall size to allow for better flow. This cannot be done with push fit. Also, i feel un easy about using any connection system where i cannot see the retainment mechanism, this makes a quick eye check impossible.
  12. abombss
    30 May 2002
    Anyone know places in the U.S. for push fit connections?
    abombss
  13. adwhitworth
    12 Mar 2003
    Try Legris - These are the people who make them :)
    www.legris.com
    You are looking at the LF3000 fittings:naughty: :naughty: :naughty: :naughty: :naughty:
