Cases Bargain Case.
Discussion in 'Hardware' started by MarkW7, 15 Jan 2009.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Hi,
    I am going to be building a new machine, i don't know much about cases but i'm looking for a cheap one, not like £100 on a case because it's mostly going to be old parts and bits.
    Main colour; black.
    Nothing to fancy
    Has to have lots of fan spaces, side, top. if poss.
    PSU with it would also be good.
    Any ideas?
    Thanks.
  2. DougEdey
    5 Jul 2005
  3. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I'd go on Ebay and get a cheap Thermaltake case
    I know I'm not meant to swear like that... but they're going for under £20 for a decent sized one
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    antec 300?
  5. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    antec three hundred (no PSU)
    antec sonata (450W Antec Earthwatts PSU)
    antec sonata 550 plus (550W Antec Earthwatts PSU)
  6. Guest-23315
    Guest-23315 Guest
    Bingo.
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    For about £20 :D
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    What about the Coolermaster Elite 330? £30.
    Recommended by Bit-Tech, and I bought one too (for my folks). Pretty good for the money. :)
  9. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    No PSU tho .
  10. KillerLettuce
    KillerLettuce custom title
    15 Jan 2009
    I agree on the antec 300. It is a great case for a budget build. Its fancy enough while not being to expensive, but it isn't built 'cheap' either.
  11. azrael-
    azrael- I'm special...
    18 May 2008
    Antec NSK4000 or NSK4480(B)?
  12. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Where has that been all my life...
  13. DougEdey
    5 Jul 2005
    Probably still there, I used them when I was in secondary school, no idea how long they were there before that
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you think you're going to get a case including a decent PSU for under £50 I think you'll be disappointed. But if you want a crap PSU, Scan Today Only often feature a Coolermaster RC-330 Black Midi Tower Case/EZcool PSU package for under £30.
  15. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Vastly overpriced. (It only been around for a year or so anyway)
  16. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Ill check out these: Antec NSK4000 or NSK4480(B)?
    and scan.
  17. azrael-
    18 May 2008
    The NSK4000 is the NSK4480 without a PSU. The NSK4480 comes with a 380W PSU (Antec EarthWatts series). The 'B' denotes the black version. There's only a silver/black version of the NSK4400.
    I recently built a new pc for a colleague around the NSK4480B and even though it's a pretty cheap case it's actually quite nice. And surprisingly quiet.
  18. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    xcase has a lot of products but,on the whole i find them more expensive than a quite a few places.Not by a lot mind,but if you cant pick it up,you dont have the option.How about some free delivery negotiations with SCAN again BT
    :thumb:
  19. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    What tools would i need to cut a case.
  20. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    generally the neatest way to cut a case is using a dremel with the angle grinder disc. I found doing a rough shape then neatening it up with a sanding attachment worked pretty well on an old steel case i had.
    Gives me some ideas actually, I've been wanting to try out a couple of theories for case flow, to get cool air to the cpu, might have to pick up a cheap steel case with a bottom mounted psu and give it a go.
