Bargin 9600
Discussion in 'bit-tech Folding Team' started by MrGumby, 26 Feb 2010.
  1. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Remember you can only add one to your basket at that price. If you add more they all go up in price.
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I bought the same card, brand new OEM from an ebay seller for £41.50 inc delivery. Go ebay if you want the 9600 GSO cards. Be warned, my XFX 9600 GSO is a whiney beast at full load.
  4. ydna666
    ydna666 What's a Dremel?
    20 Jun 2009
    Thanks for this :thumb:
  5. cdb
    cdb No comment
    25 Apr 2009
    Is this a DDR2 or DDR3 card? Mine just came through with DDR2 on the box, but DDR3 on the invoice.
    If anyone has one with DDR2 on the box what ppd are you getting on the 353pt WUs for example?
  6. saspro
    saspro IT monkey
    23 Apr 2009
    The DDR2 ones are rather pony.
    I had 2 and got rid quickly as I was getting a couple of thousand ppd less than I should've
  7. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    The older 348Mb (DDR3) ones are by far the best, if you can get a 680/1700/950 over-clocked one even better, however they will all take a 1718 shader freq, even the 8800GSs. I have;
    12 x 580/1450/900
    3 x 680/1700/950
    3 x 580/1450/700 (8800GS)
    All have the shaders over-clocked to 1718 and all run pretty much identical PPD anywhere from 3500-4500 depending on WU. With the 3469/70 units they will do 6500-7000 but they are rare as hens teeth.
  8. cdb
    cdb No comment
    25 Apr 2009
    I've been trying to ge through to Aria for the last 2 days to return this item as it's misadvertised (ie crap for folding) but they won't answer, they just keep you on hold racking the money up.:miffed:
    Having started to search the net for a non 0844 number I found a couple of review sites for Aria and they were slated by alot of people, so I would suggest anyone else avoids this firm.
    Looks like I'm stuck with this card now.:wallbash:
  9. Ph4ZeD
    22 Jul 2009
    How is the item misadvertised?
  10. cdb
    cdb No comment
    25 Apr 2009
    As I said above. It's shown as DDR3 on the site, but on the box it is DDR2. That makes a big difference to folding performance.
  11. mrbungle
    20 Sep 2004
    ddr2 cripples the card
    ill avoid aria if they dont answer the fones
  12. MNC Fear
    MNC Fear Banned
    7 Feb 2005
    Ive never really done folding before
    wouldnt it hammer my leccy bill and have my missus wanting to moan at me even more?
  13. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Welcome to the team then :)
    That depends on what hardware you're running, i.e. just a single PC with a single graphics card? If so, it won't have much of an increase on your electricity bill. It's only when you're running multiple PCs do you really see a big increase.
  14. cdb
    cdb No comment
    25 Apr 2009
    My currebt PC, an I7 860 with one 8800GT was using somewhere around 220W including 40W for the monitor I think. Overclocked and with 4 8800GT it can use over 600W with the monitor on.
    So it could add say £25 to £70ish per month to your electric bill if you left everything folding 24/7.
  15. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
  16. Ph4ZeD
    22 Jul 2009
    I'm not sure what PPD they produce, but at £28 they should be decent value. A guy on the marketplace is selling a 8800GT for £40 inc delivery, which is another very good £/PPD ratio deal.
  17. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    From the picture they don't have a separate power supply cable, so all the power will be coming from the motherboard slots. 3 or 4 of these may be pushing the board hardware to cope. Otherwise they look like a bargain, you won't get very high PPD (2-3000 each perhaps) but good PPD/watt. And you could try overclocking the shaders a bit.:D
  18. rob the bank
    13 Mar 2010
    Good point re mobo power.
    So if a board is using an 8pin CPU and a 24pin ATX, what can it push out the PCI-E's?
    I have two spare at present a Striker Extreme Celeron 3ghz, and a P6TSE i7 920.
    These are just used for folding.
    Cheers!
  19. Christopher N. Lew
    23 Apr 2009
    IIRC the PCIe standard calls for 75 watts through the motherboard slot, so with 4 cards the total would be heading for 300W. Again, IIRC, the 8-pin EPS12v supplies up to 300W but is meant primarily to supply modern PSUs.
    If you are asking board/CPU would best fit your plan, I'd try out Celeron first.
    Let us know how you get on :D
