Linux bash script problems
Discussion in 'Software' started by Herbicide, 29 Mar 2009.
  1. Herbicide
    Herbicide Lurktacular
    27 May 2004
    I came across this instructable and have decided that the whole thing looks easy enough.
    Heh.
    I've looked at and modified the provided shell script, but I'm a bit stuck.
    Code:
    #! /usr/bin bash
    ## Get basic compile tools if you don't already got 'em:
    ## (removed those - have them already)
    ## Uncomment the relevant line below before running.
     slapt-get --install flex bison byacc
    # yum install flex bison byacc gcc
    ## This is going to be the base install directory
    cd /usr/local/avr
    ## Get the source files
    ## Note: you can get an updated version of GCC if you want.
    ## This one works for me.
    wget http://download.savannah.gnu.org/releases/avr-libc/avr-libc-1.6.4.tar.bz2
    wget http://download.savannah.gnu.org/releases/avrdude/avrdude-5.6.tar.gz
    ## Unpack them all
    tar xvjf avr-libc-1.6.4.tar.bz2
    tar xvzf avrdude-5.6.tar.gz
    ## And start compiling.  This takes a while.  Go get some tea.
    # Binutils
    cd binutils-2.17.50.0.17-i486-1/
    ./configure --prefix=/usr/local/avr --target=avr
    make
    make install
    cd ..
    # Update path, b/c GCC needs the avr linker from binutils above
    export PATH=$PATH:/usr/local/avr/bin
    # GCC
    cd gcc-4.1.2/  # note: if you changed GCC versions above, change this!
    mkdir avr-gcc  # GCC needs a sub-directory to compile into
    cd avr-gcc
    ../configure --prefix=/usr/local/avr \
                  --target=avr --enable-languages="c" \
                  --disable-nls
    make
    make install
    cd ../..
    # AVR LibC
    ## Note: build method changed recently -- much cleaner now.
    cd avr-libc-1.4.5/
    ./configure --build=`./config.guess` --host=avr --prefix=/usr/local/avr
    make
    make install
    cd ..
    # AVRdude
    cd avrdude-5.6/
    make
    make install
    cd ..
    ## Now set up paths and we're done
    echo "
    ## Added to put avr-gcc and utils in the search path
    export PATH=\$PATH:/usr/local/avr/bin" | cat >> /etc/profile
    Anyway, I sh avrinstaller.sh, hit enter and wait.
    It's all OK, until:
    avrinstaller.sh: line 25: cd: binutils-2.17.50.0.17-i486-1/: No such file or directory
    avrinstaller.sh: line 26: ./configure: No such file or directory
    make: *** No targets specified and no makefile found. Stop.
    make: *** No rule to make target `install'. Stop.
    avrinstaller.sh: line 35: cd: gcc-4.1.2/: No such file or directory
    mkdir: cannot create directory `avr-gcc': File exists
    avrinstaller.sh: line 38: ../configure: No such file or directory
    avrinstaller.sh: line 47: cd: avr-libc-1.4.5/: No such file or directory
    avrinstaller.sh: line 48: ./config.guess: No such file or directory
    avrinstaller.sh: line 48: ./configure: No such file or directory
    make: Nothing to be done for `install'.
    avrinstaller.sh: line 54: cd: avrdude-5.6/: No such file or directory
    avrinstaller.sh: line 55: ./configure: No such file or directory
    Bearing in mind I'm running slackware 12.1, what do I need to change/sort/install to get this to work?
    Oh, the full path to binutils (which is where it all seems to fall over) is:
    /mnt/hdd2/root/Pseudo/ISO/packages/dev/binutils-2.17.50.0.17-i486-1.tlz
  2. Glider
    Glider /dev/null
    2 Aug 2005
    It almost seems too easy but:
    Code:
    cd /mnt/hdd2/root/Pseudo/ISO/packages/dev
    sh <path to avrinstaller.sh>
  3. Herbicide
    27 May 2004
    Code:
    metheuselah://home/simon
    root:# cd /mnt/hdd2/root/Pseudo/ISO/packages/dev
    bash: cd: /mnt/hdd2/root/Pseudo/ISO/packages/dev: No such file or directory
    root:#
    :( :grr:
  4. Glider
    Glider /dev/null
    2 Aug 2005
    You sure you put the binutils package in the correct directory?
  5. Herbicide
    27 May 2004
    As far as I'm aware I didn't do anything, it must have installed with the distro.
    slapt-get --install binutils
    shows it as up to date.
  6. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    If you have locate installed, try and locate it, and check where the folder really is?
  7. trigger
    trigger Procrastinator
    22 Mar 2004
    Looking at the full version of that script it appears that it downloads a specific version of Binutils and GCC, which you've removed; however you haven't removed the lines that would have compiled and installed them, so you want to either reinstate the wget and tar lines or remove the lines that install Binutils and GCC.
  8. Herbicide
    27 May 2004
    locate, slocate and mlocate all fail to work.
    :wallbash:
  9. Zoon
    12 Mar 2001
    Does the error message state it can't find the locate database? In which case run locate.updatedb or whatever your distro names it!
  10. Herbicide
    27 May 2004
    Thanks.
    It's running now.
    This is more involved than I usually get - slapt-get --install [package] is usually my limit.
    Edit: Nope - same problem.
  11. trigger
    22 Mar 2004
    Did you remove the GCC and Binutils install lines or add the wget and tar lines back in? I would guess it would be better to remove the install lines as you already have them both installed from your package manager. Also is avr and avrdude not in your distro's package manager? They are certainly in Debian...
  12. Herbicide
    27 May 2004
    I removed them.
    Code:
    #! /usr/bin bash
    cd /usr/local/avr
    ## Unpack them all
    # AVR LibC
    cd avr-libc-1.4.5/
    make
    make install
    cd ..
    # AVRdude
    cd avrdude-5.6/
    make
    make install
    cd ..
    echo "
    here's the output where it went wrong:
    avrdude-5.6/doc/Makefile.in
    avrdude-5.6/doc/stamp-vti
    avrdude-5.6/doc/version.texi
    avrdude-5.6/doc/TODO
    avrdude-5.6/doc/mdate-sh
    avrdude-5.6/doc/texinfo.tex
    avrdude-5.6/doc/avrdude.texi
    avrdude-5.6/doc/avrdude.info
    avrinstaller2.sh: line 27: cd: avr-libc-1.4.5/: No such file or directory
    avrinstaller2.sh: line 28: ./config.guess: No such file or directory
    avrinstaller2.sh: line 28: ./configure: No such file or directory
    avrinstaller2.sh: line 34: cd: avrdude-5.6/: No such file or directory
    avrinstaller2.sh: line 35: ./configure: No such file or directory
    the only result I get for 'avr' is libmcrypt...
  13. trigger
    22 Mar 2004
    Ah, I see it, you are downloading avr-libc-1.6.4 but trying to cd to avr-libc-1.4.5. If you change the references to 1.4.5 to 1.6.4, and give it another go, hopefully it'll work.
  14. Herbicide
    27 May 2004
    :rolleyes: :wallbash:
    thanks.
    *fingers crossed*
    I think it's worked!
    Just need some components now.
    /me scavenges.
    y'know - this roll-your-own compile and install thing is simpler than I thought...
