Build Advice Basic Build - £250 Budget Help Needed
Discussion in 'Hardware' started by DanFerret, 24 Jan 2010.
  1. DanFerret
    DanFerret What's a Dremel?
    24 Jan 2010
    Hey guys,
    In desperate need of a new second computer as our old one is far too out of date to do anything worthwhile.
    Have a budget of £250, all I need to put together is a main tower though as I already have a monitor, mouse, keyboard and speakers.
    Have experience building computers but not too hot on choosing components so any help would be appreciated.
  2. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    It may be worth updating the PC you already have, I haven't worked with this size budget before, sorry I couldn't be of assistance. :(
  3. DanFerret
    24 Jan 2010
    Old PC is a Dell Inspiron 1100
    * Intel Celeron 2.0 GHz Processor
    * 256 MB PC2100 DDR Memory
    * 30 Gigabyte Hard Drive
    * 24x CD-ROM Optical Drive
    * 15" XGA (1024x768) LCD and Intel Extreme 3D Graphics with 64MB Shared Memory
    * AC'97 Audio
    * v.92 56Kbps Modem and 10/100 Ethernet
    * Two USB 2.0 Ports and One Type II PC Card Slot
    * 13.1" x 10.8" x 1.8" @ 7.8 lbs.
    * Windows XP Home Operating System
    Not sure any of that is much use in 2010 lol.
    Only difference to those specs is I upgraded the Ram to 2Gb a year so ago.
  4. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I... wow. £250 is buying secondhand components, I don't think you can put together a machine of any significant power for that sort of money with firsthand parts. I would have a look on eBay for secondhand computers, and get an idea of what you can buy. Really, for a decent machine, you're going to need at least £100 more.
    What do you intend to use it for?
    Alternatively, have you considered a nettop?
  5. DanFerret
    24 Jan 2010
    Hmm so do Im going to struggle with this sort of budget?
    Its basically going to be used for everyday things like internet, watching videos and homework for my brothers. It doesn't need to be brilliant but I don't want to put together something that's not worth it just to stick to a low budget.
    Budget is only that low because that is all my mum will help out with, anything over I would have to pay for lol.
  6. Lucy2005
    Lucy2005 What's a Dremel?
    25 Jun 2004
    hello Dan, hope i can help out. Since your on such a tight budget you wont get a lot of bang for your buck so to speak, but my reccomendations are as follows
    btw to get the items use the quickfind numbers and type them in the search box to get straight to the components
    i havnt included a graphics card but the motherboard ive suggested has a radeon HD4200 built in so at least you can play older games. Also im guessing youve got the operating system sorted or i dont think your gunna be able to afford anything tbh. Also not included a dvd drive as im guessing you'll have on in the old rig.
    Is this any good to you? £7 over but tbh if you changed it to 1gb of ram it'll be under budget but if your using vista/7 then 1gb isnt enough.
    crap forgot to put its all from ebuyer.com
  7. PureSilver
    16 Dec 2008
    Lucy's idea's a good one because I don't think your old computer is worth very much; stripping it for parts isn't a bad idea. You'll need an OS, though; if you're still at school you might be able to get one cheaply. Alternatively, if by homework you mean word processing, then I would pick up a high-spec ION nettop, which usually come with an OS. Obviously, you will not be able to play any games on this thing, but if browsing, word processing and video watching are the most you're going to ask of it then it should be OK.
    If you can stomach second-hand buying I would still recommend that. You should get a lot more computer for your money; £250 sits right at the edge of 'not worth buying a computer.'
  8. DanFerret
    24 Jan 2010
    Thanks for the posts people :)
    In regards to an OS I can get those for free via Uni so thats saved me some money.
    I dont have a DVD drive in the old PC but I do have one in a broken one sitting in my garage right now lol. Its quite old too though so might just add fork out for one.
    The computer wont be used for gaming so Im guessing the onboard graphics card will be fine, will it be enough for HD video?
  9. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    TBH, a nettop isn't much faster than his old computer, I'd go with the system specced out above. You can always get a smaller hard drive if you want to save a few quid.
  10. DanFerret
    24 Jan 2010
    With the specs listed there how easy is it to upgrade components in the future?
  11. oasked
    24 Aug 2005
    Very easy. You can easily swap in a faster CPU, more RAM or a graphics card when funds allow.
    For now though, it should be a great speed-boost and it should do HD-video very well :)
  12. ac4155
    ac4155 What's a Dremel?
    27 Dec 2009
  13. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    yeah the build above will be fine for hd video
    but you could probably shop around and shave £15 off the Mobo allowing you to buy a new DVD drive
    also depending on you usage you could shave a tenner off the hard drive as well
    also the 350W Silverstone ST35F is £30 @scan so there is another £10 there
  14. DanFerret
    24 Jan 2010
    Not too keen on a netbook really. Would prefer an actual PC.
    Will have a shop around and see how much I can save by shopping in different places.
    Cant thank you guys for all your help.
    Will hopefully have all my components ordered by this evening.
  15. Slash88
    Slash88 Just starting out
    2 Jan 2010
  16. Lucy2005
    25 Jun 2004
    do scan do free delivery tho? remember thats the beauty of ebuyer plus ive never had to wait the full 5 working days, it usually gets deliverd within 3 max.
    The onboard video will do 720p .mkv no problem but it wont do 1080p (i have a htpc with the 785g chipset)
    Also theres no upgrade path with a nettop, at least your getting socket am3 and ddr3 memory so it should last you a few years at least, but its all down to your personal preference we can only give you advice, good luck and i hope your happy with what you end up with :)
  17. DanFerret
    24 Jan 2010
  18. yakyb
    10 Oct 2006
    they also ran free delivery from here a while back
    part of the reason i use them just wish they had a better memory selection
  19. DanFerret
    24 Jan 2010
  20. mrbungle
    20 Sep 2004
    all very similar
