Guide Basic Case Window & Install Video
Discussion in 'Modding' started by mnpctech, 28 May 2007.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Hey Gang, Heres the first in a series of diy videos where I go "Back to Basics" and share my techniques. It's always good to refresh yourself once in awhile :)
    DO-IT-YOURSELF CASE WINDOW & INSTALL
  2. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Brilliant, thanks. That is pretty much exactly what I want to do. However I have never used a jigsaw (I am sure my dad has one) so how do you recommend that I practice. It is aluminium that I will want to be cutting.
    Thanks again for a great vid.
  3. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    I was supposed to comment earlier, amazing vid!
    As for practice, try a blank sheet of metal (like an aluminium sheet).
  4. culley
    culley What's a Dremel?
    12 Jul 2006
    Nice work, I've seen the guys at Orange County Choppers on American Chopper use that strong double sided tape to stick aluminium onto a aluminium fender so it must be strong!
  5. bumfluff
    18 Aug 2006
    What do B&Q have i the way of small pieces of blank Aluminium, how much would it be? I don't need much, just enough to know how I would go about cutting holes with my Dremel and a jigsaw.
  6. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    Excelent guide, exactly what I was planning to do to my new case when I get it (same case too so even better:))
  7. bumfluff
    18 Aug 2006
    OK, it is actually stell that the case's side panels are made of, making things slightly harder, especially for the single speed jigsaw that I have.
  8. mnpctech
    21 Apr 2003
    Thank you everybody :thumb:
    Have you asked your father for assistance? He could show you the basics and supervise you. Also remember to wear safety glasses.
    For cutting aluminum, you should use a minimum 18 TPI cutting blade for metal or plastic.
  9. bumfluff
    18 Aug 2006
    My dad works away most of the time so I onyl see him at weekends and I will moslt be working during the week. I also came up with the idea of getting a couple of stainless steel baking trays to practice on as they should be slightly cheaper than getting a big sheet of steel (the case is actually only aluminium on the front I now realise).
  10. MrWizard6600
    MrWizard6600 What's a Dremel?
    20 Jun 2006
    I onno man...
    Bolts > tape
  11. mnpctech
    21 Apr 2003
    Good idea. Practice makes perfect! :dremel:
  12. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    You guys should sell the wholesale size rolls of that tape on your site! ;)
    Nice vid-mod.
    -CollinstheClown
  13. mnpctech
    21 Apr 2003
    You can buy large size rolls of the tape :thumb:
    Goto BindingSource's 3M Tapes
    #4910, 1" wide @ 36yards for $73.19
  14. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Ah, see I went to 3M's site and I didnt see it. Thanks for the link! I may just get me some now. :)
    -CollinstheClown
  15. mnpctech
    21 Apr 2003
    You bet Collins! btw: I'm currently recording a video guide/worklog of an old beige case transformation. These are just stills from the video. I hope to have the first 3 segments posted on my YouTube page soon.
  16. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Cool beans. Gotta tell ya Bill, I've been a fan for ages. And watching you work is like...well, you don't wanna know :D. Thanks for all the vids you posted in the past, and all the killer mods you've done! You are truly an inspiration with what you do. :rock:
    As a side-note, I'm actually working on your fav chassis as we speak....the CF-1009.
  17. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    When it comes to taping stuff down, at least on flat surface, double sided carpet tape is awesome. We used it at my last job to hold down honeycomb to a CNC mill. If you put a flat sheet of metal down on the bed with it, and completely covered the bottom of the piece, and stood on it to press it down firm... you werent getting it off without a fight.
  18. Matteh117
    Matteh117 -LoGiSTiX-
    14 Aug 2007
    Thanks for sharing this. Will be getting all the materials next week and trying this myself. :)
  19. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    Give us more of them bill!!!!! THEY ARE SO SIMPLE I LOVE OLDSCHOOL MODS!!!! BRing us more!! :thumb:
  20. mnpctech
    21 Apr 2003
    Thank you very much. Comments like yours make all of the long hours worth it :clap:
    Indeed, CF-1009 rawk. I just wish I had bought up a ton of them when I had the chance 2 years ago. Oh well, that makes them even more special I suppose :hip:
    Thats great advice Conkbot. Thanks for sharing this!
    You bet! I'm editing a new 3 part segment as I'm writing this.
    We're also planning a mod for the Qmicra for PCDesignlab. The mod will honor 75 year anniversary of the `32 deuce coupe. We want to record all of the build highlights. I just wish I could find a real `32 to drive in the video :hip:
