Electronics Basic Circuits
Discussion in 'Modding' started by Duste, 7 Oct 2006.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Anyone know where I can learn how to make basic circuits? Aswell as where I can buy the required equipment.
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Well your going to need the obivious things would be a soldering iron, and reel of solder and what ever componants you'll need, also if you've never used a soldering iron theres tons of tutorails around, inculding video ones. As for buying your bits maplin's is always a good place, not too pricey other wise just look around for some online shops :thumb:
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Unfortunately, Maplin doesn't have any branches in Western Australia ;) Dick Smith would be the equivalent, I think.
    Best thing to learn is to buy one of those "100 circuits in a box" kits, they should allow you to experiment; I'm not sure how good they are at describing why and how the circuit works though? Another option is to see if your local college runs electronics classes.
    There are also loads of books which will introduce you to electronics.
  4. Duste
    1 Oct 2006
    Thanks, and yeah, I have experience with soldering iron, I had a nice scar on my arm for a few years - in year 5, we were doing some electrical *stuff, some kid bumped into me, soldering iron went straight onto me arm, it melted a couple layers of skin. :(
    Not sure if Dick Smith's is open tomorrow. If it is, I'll go and have a look, if not I'll just wait until Monday.
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I did the palm of my hand a few years ago, boy that hurt and took ages to heal.
    I knocked it of the stand and caught it by the wrong end.
    try here
    http://www.electronics-lab.com/forum/index.php
  6. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    To make a circuit board you need a blank copper curcuit board, etching solution, sharpie, plastic container that can fit the curcuit, and rubbing alcohol.
    1) Use the sharpie to draw your curcuit design on the board
    2) Fill the plastic container with the solution
    3) Place board in solution and wait about 15 minutes or so, while moveing the curcuit around with a stick or something(im pretty sure you move it, its been a while)
    4) Pull out the curcuit with pliers/tweezers/etc...
    5) Run it under cold water
    6) Use rubbing alcohol to remove marker'
    7) Now you have a curcuit board :) Hope that helped.
    -CollinstheClown
  7. kbn
    kbn What's a Dremel?
    17 Mar 2004
    for learning its probably best just to use protoboard. I got some with my last order, saves a LOT of time from soldering on stripboard
  8. gideon
    gideon What's a Dremel?
    27 Feb 2006
    maybe play with simulation programs like crocodile physics
