Basic System Build
Discussion in 'Hardware' started by Spacecowboy92, 24 Sep 2007.
  1. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    I've been asked by a friend to piece together a system around the £350 mark.
    Usage will mostly be Internet/E-mail usage but "with a fair bit of power" so a bit of gaming on the side. Going to £400 is fine but try to keep it down.
    I've been looking at the E6300 or the E6320 as a core or something around that price. Again, none of the components need to be blazing fast as long as they do the job and can be upgraded in the furure.
    Thanks Guys.:thumb:
  2. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    If you want a cheap system, then an E4400 or E2160/2180 would be better choices for the CPU, as they are cheaper and still perform quite well.
  3. Spacecowboy92
    10 Apr 2006
  4. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Not quite
    E4400
    P35-DS3R (It's p35 chipset, vs p965)
    2gb ram (It helps a lot more)
    7900GS or X1950Pro (Faster than the 8600, cheaper)
    Corsair VX 450
  5. Spacecowboy92
    10 Apr 2006
  6. Gravemind123
    26 Aug 2006
    Looks like a solid system, even good for overclocking if you are so inclined to tinker around with settings. Even if not, it's a good build, having 2GB of ram, an E4400 and a similar performing video card, I can say you will not be disappointed by the performance.
  7. Grings
    Grings I am rubber, you are glue
    21 Sep 2007
  8. Spacecowboy92
    10 Apr 2006
    That Ram does look pretty sweet. I think I mighy have to buy some for myself.
  9. Spacecowboy92
    10 Apr 2006
    Another thing I just rembered, A PSU. I thought I had two in my scrap heap that could power it but I found I gave them away and only have a generic 350W one left. That may get it off the ground but I wouldent want to keep it there for long. Whats the lowest voltage that could comfortably power this system?
