Windows BAT file problem
Discussion in 'Software' started by Psycho, 12 May 2012.
  1. Psycho
    Psycho Average
    15 Sep 2009
    Hello everyone. The problem I have is that I can't open BAT files at all, the cmd doesn't even show up. I tried searching all over the internet for an answer but found nothing.
    To be more specific: I double click a BAT file but does absolutely nothing, no cmd, no 'Open with', no error, no nothing. The icon isn't even a BAT icon I remember (exe with a gear inside), it's just one of those misc files icons. Right clicking it shows no option to run it, nor to run it with any other program. I am currently using Windows XP.
    Thanks in advance to any answer received.
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Check filetype association... where ever that is located for XP, I don't remember.
  3. Psycho
    Psycho Average
    15 Sep 2009
    It's still BAT file.
  4. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    what if you open up cmd and drag it in and run it, does it work then?
  5. IvanIvanovich
    31 Aug 2008
    But is the association set to cmd still? Or what if anything is it set to open with by default?
  6. Psycho
    Psycho Average
    15 Sep 2009
    @Deathtaker Doesn't recognize it either.
    @lysol Type of file is BAT already, but there's nothing set by default to open it (As far as I see) and I can't find a way to set one.
  7. IvanIvanovich
    31 Aug 2008
    Psycho likes this.
  8. Psycho
    Psycho Average
    15 Sep 2009
    It worked, thanks a lot my friend.
  9. IvanIvanovich
    31 Aug 2008
