Windows Batch image resizing
Discussion in 'Software' started by Lazy, 5 Aug 2002.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    as i email a lot of images in my articles etc...
    i want to be able to resize a large amount of images so that they are of suitable size and are there for not to big to email.
    any there any programmes that can do this?
  2. inder
    inder Mr.Modtown
    17 Jul 2002
    when you say resize, do you mean like by pixel size or by file size?
    www.winzip.com or www.winrar.com will compress your files, by images dont compress well
    you can create a batch resizing action in photoshop, point it to a dir and watch it whizz thru and resize them all for you...
  3. monty12
    monty12 What's a Dremel?
    1 Jul 2002
    if you want to batch resize images, i would recommend Photoshop, it has the ability to set up actions. and resizing is one of them.
    recently i had to resize mug shots of people in my company. 726 in total. I had to options Paint Shop Pro or Photoshop. I started off in PSP, but it involved me having to to repeatedly do the same thing. Open the image, press Shift + S hit Enter, Ctrl + S. For every image. Pain it the butt.
    I asked a friend who is a graphic designer, and he pointed me in the right direction. And this was using Photoshop.
  4. inder
    inder Mr.Modtown
    17 Jul 2002
    thats two for photoshop :D
    also with the actions, you can do other stuff as well, so it will do the same to all images, like add a watermark, autolevels, change dpi etc
    very useful tool in PS!
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    i thought it might do it so i got a copy of it at my lan party.
    cheers.
  6. peteone
    peteone Minimodder
    5 Jun 2002
    Fireworks is what i use you can scale and it also has excelent compression.
    Pete.
  7. RTT
    RTT #parp
    12 Mar 2001
    Get Jasc Image robot, designed for batch image adjustments, does EVERYTHING :)
    (we use it here @ Bit)
  8. pszaro
    pszaro What's a Dremel?
    11 Mar 2002
    photoshop... photoshop... photoshop... :D
  9. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    grab Irfan image viewer.. its the best freeware viewer, converter, resizer out there that will do batch resizes and converts as well as batch renaming.. very usefull little (less than 1mb) proggie..
    http://www.irfanview.com/
    -scoob8000
