Gaming Batman: Arkham City PC Review
Discussion in 'Article Discussion' started by arcticstoat, 2 Dec 2011.
  1. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    "Is it a bird?....Is it a plane?...NO!....Its...erm actually it is a plane, dammit, should've gone to Specsavers".
  2. jake.gmB
    jake.gmB What's a Dremel?
    7 Dec 2011
    Why was my previous post disallowed ? there was nothing wrong with it and i left useful tweaks for people so the game would play better
  3. rogerrabbits
    rogerrabbits What's a Dremel?
    24 May 2011
    It's the fighting I like the most. I was worried at first because it was all just left click click click click. But after you unlock more abilities it ends up being a proper fighting game.
  4. Krikkit
    21 Jan 2003
    Quite the opposite - an excellent post, it just had to be moderated first. :)
  5. [EOCF] Tim
    [EOCF] Tim What's a Dremel?
    26 Oct 2005
    Finished the main campaign and several side quests now, and I must say I thoroughly enjoyed the game, more then Arkham Asylum. I think this game definitely deserves a score in the 90% range. It runs superb in DX9, and the artwork and textures are so beautiful I had to stop and just walk around instead of flying/running. Magnificient work of art. Having played it on Hard I definitely found it challenging and had to restart a battle many times because of being pummeled left right and center. Timing is crucial, and with the additional tricks up the bat and cat's sleeve I found it enjoyable. The riddlers challenges are on the easy side, easier then AA I think, but still good fun to chase down.
  6. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
  7. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    Just installed I think it's had a few patches since the review.
    Anyway it looks absolutely stunning and the combat on hard is actually quite........hard.
    I turned the detail setting down from 'very high' to 'high' on an 8800gt and it's very playable, of course physx is off.
    I think the game does a good job of being playable on lower cards but also caters for the high end user with dx11, physx, tessellation and 3d.
  8. andyb123
    andyb123 What's a Dremel?
    10 Mar 2011
    I quite like these sandbox games but sometimes they go a bit ott on all the extra side missions - they just get really repetetive
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    good game.. felt like I was really in gotham
    wrote a vb script if anyone wanted to use it.. it just backs up your live saves as they happen- then you can go back and play any point.. just change the paths =]
    Code:
    ' vbscript- batman.vbs (.) (.)#! thehippoz
    ' change the strFolder/strProgram strings below to match your
    ' save/game paths..
    ' save and put both batman.vbs and monitor.vbs into the strFolder..
    ' create a shortcut to the strFolder and run batman.vbs
    ' was made to launch both BatmanAC.exe and monitor.vbs. it'll backup
    ' all gfwl saves while playing from any of the save slots.. it can
    ' also be used for other games with a bit of tweaking.. if you have
    ' any issues- double check the drive and path..
    strDrive = "C:"
    strFolder = "\Users\User Name\Documents\WB Games\Batman Arkham City\SaveData\xxxxxxxxxxxxxxx\"
    strProgram = "\Program Files (x86)\Batman Arkham City\Binaries\Win32\BatmanAC.exe"
    intCount = "1"
    Set objSh = CreateObject("Shell.Application")
    objSh.ShellExecute strDrive & strProgram, "" , "", "", 1
    objSh.ShellExecute "C:\Windows\System32\wscript.exe", """" &_
    strDrive & strFolder & """" & "monitor.vbs" , "", "", 1
    strFolder = Replace(strFolder, "\", "\\")
    Set objWMIService = GetObject( "winmgmts:" &_
    "{impersonationLevel=impersonate}!\\" & ".\root\cimv2" )
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    strQuery = "Select * From __InstanceOperationEvent" &_
    " Within 2 Where Targetinstance Isa 'CIM_DataFile'" &_
    " And TargetInstance.Drive='" & strDrive & "'" &_
    " And TargetInstance.Path='" & strFolder & "'"
    Set colEvents = objWMIService. ExecNotificationQuery (strQuery)
    Do
        Set objEvent = colEvents.NextEvent()
        Set objTargetInst = objEvent.TargetInstance
        Select Case objEvent.Path_.Class
            Case "__InstanceModificationEvent"
                strFile = objTargetInst.Name & ".backup "
                Do While (objFSO.FileExists(strFile & intCount))
                    intCount = intCount + 1
                Loop
                WScript.sleep 6000
                If (InStr(objTargetInst.Name, "backup")) = 0 &_
                    (InStr(objTargetInst.Name, "vbs")) = 0 Then
                    objFSO.CopyFile objTargetInst.Name , strFile & intCount
                End If
        End Select
    Loop
    Code:
    ' vbscript- monitor.vbs
        WScript.sleep 10000
        Set objWMIService = GetObject( "winmgmts:" & "{impersonationLevel=impersonate}!\\" & ".\root\cimv2" )
        Set WMI=GetObject("winmgmts:{impersonationLevel=impersonate}").ExecQuery ("select * from Win32_Process")
    strProcess = "BatmanAC.exe"
    strWMIQuery = "Select * from Win32_Process where name like '" & strProcess & "'"
    Do While objWMIService.ExecQuery(strWMIQuery).Count > 0
        WScript.sleep 10000
    Loop
    For Each Process in WMI
    If process.name = "wscript.exe" Then
        Process.terminate
       End If
    Next
  10. faugusztin
    11 Aug 2008
    Did they finally fixed the bug with disappearing saves ? If not, then your script has a different use too :naughty:.
  11. thehippoz
    19 Dec 2008
    yeah can use it to restore if you want =] it's pretty handy like when you have to choose when catwoman is breaking into the vault..
    having one save with no backups is for consoles
    ok made changes above.. instead of talking about it lol
    hope it helps.. :thumb:
  12. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I've just started playing it (about 3 hours in) and I'm not feeling the open world design. I preferred the Arkham Asylum style gameplay.
  13. thehippoz
    19 Dec 2008
    while I was in my pictures folder for diablo.. thought might as well post up some from batman
    the game is beautiful imo.. well least a lot better than diablo =]
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
Tags: Add Tags
