Case Mod - In Progress Batman : Arkham City Update 01/06/2012 Finished Pictures
Discussion in 'Project Logs' started by jj_sky5000, 16 Dec 2011.
  1. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Happy Holidays,
    My oringinal Idea for the case mod, was to re mod this NZXT Vulcan micro-atz case all i was going to do was Batman etching on the window for my 7 year old son, Just a little weekend project, the ultimate goal was to make a nice little Lan case ,but when i started getting a few more ideas came to mind .
    I very thankful for Biostar, Intel and NZXT . With out there support these are just visions on paper. I showed my friend at Boistar the progress of teh case and he ask to showcase it in Vegas for CES.
    I started working on the side panel first to replace it with plexi.
    making the window opening bigger with a dremal tool
    all is left is to is a few places to File.
    Next up to see how it look on the case
    removing the rivots and the disassemblyhas begun
    6 differnt grades of sand paper for the finish
  2. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Ok brought out the heavy duty paint stripper!!!! Yea thats a airplane on the can, alwasy use proper Ventilation and a mask or you will feel like your flying !!!
    You know its done its job when it starts to peal off
    60 Grit !!!
    And when the sanding is done
    repainted the top fan cover to a metallic silver
  3. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Decided to change the front panel a bit and add a little Batman touch to it.
    Fan Cut out
    I will be re-using the orginal mesh from the side panel for the front
    I had some left over anodized aluminium from my other super secret project
    With a scroll Saw and a file you can do amaizing things
    all thats is left is have the Rez cut out and add power button and a little polishing
    Alot more too do
    Thank you again for checking the project out.
  4. Nixjuh
    Nixjuh New Member
    11 Dec 2011
    Hey, that's a really cool theme! :)
    And i like the way it already looks!
    Maybe it would be an idea to build a gargoyle and put batman on top of it?
    Like this:
    Keep up the great modding!!
  5. OmightyOne
    OmightyOne Member
    7 Nov 2011
    keep it up! what colour will the case end up?
  6. slipperyskip
    slipperyskip Member
    26 Oct 2003
    All right James! Headed back to the big show. Awesome. I'm sure you will build something to wow the crowds like last year.
    PS Work on your packing skills. :D
  7. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    I have learned. I dont pack the mods myself anymore professional packers Cheesecake
    I shipped 2 ice case mods and they made it in one piece not 500 :)
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    :clap::)
    Subbed, looking good :).
  9. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Its all starting to come together down the Final stretch before CES. Primer and paint
    More Primer
    Decided to cut the top out for a place to fill the watercooling
    More Sanding to get the annodized marks removed
    Side panel was next , 50 grit,100, 150, 400, 1000, 1500 and 2000 for a finish
    Interior of teh Side Panal Black with metal flakes
    Small teaser
    Thanks for looking
  10. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Happy New year !!!! Back to Modding
    Finishing painting the frame
    Started assembly Case feet on first
    Adding the rad
    Thanks Db for the idea of adding some lights behind the bat should also cast a shadow
    My intial thought was glue or double sided tape to attched to teh front panel. but it for my son, I better screw it in. :)
    another teaser
    Thanks for looking
  11. bulldogjeff
    2 Mar 2010
    I really like this one. Looks nothing like the original case. Got some lovely little touches. Thats proper modding, nice work dude.
  12. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Small update before the final photos and off to CES
    A big thank to NZXT for Sending me the HALE90 850W Power supply to Showcase in the MOD.
    The black and white theme ps went perfectly with the mod
    Also another Big Thank you to Biostar supporting the mod as well, By sending the Extreme Edition TH67XE Micro ATX MB
    Adding The Blood Red Danger Den waterblock
    Black and red going together well
    Finished the water cooling loop
    A little Batman
    Teaser ( its time to Signal Batman)
    Thanks again. come back tommorrow for the Finished Photos.
    Waynio likes this.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Love that last shot :) looks excellent overall JJ :). rep
  14. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Thank you. The Bat came out better than exspected.
  15. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Final Pictures are up!!!!! Thanks again for following the MOD. And a Big Thank you to Intel, Biostar and NZXT If you going to CES and stopping by The NZXT Suite you can check it out.
  16. OC Maximus
    OC Maximus New Member
    7 Aug 2010
    Why the cyclops bat?
    Why not use 3m double sided tape?
    Screw it in?
    No need.
    The rest is.... "Holy sht Batman, this project is fantastic."
  17. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    Funny thing is That what i used on my first pics and ran out lol ( i was on a deadline) i have a few changes when it comes back, I watch and listen ::)
  18. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    2012 CES Biostar Suite pics then its of to The NZXT Suite for the remainder of the Show
    Thanks for looking !!!
  19. MjFrosty
    MjFrosty New Member
    3 Aug 2011
    nice job, looks fantastic
  20. jj_sky5000
    jj_sky5000 Member
    25 Dec 2009
    thank you
