Scratch Build – In Progress BATMAN THE DARK KNIGHT
Discussion in 'Project Logs' started by TodMod, 23 Dec 2020.
  1. TodMod
    TodMod Active Member
    14 Dec 2018
    Greetings folks
    Here we are,ready to start with a new scratch build.
    This time the mod is dedicated to my DC favorite suoerhero.
    BATMAN THE DARK KNIGHT.
    This project will take part at the COOLER MASTER WORLD SERIES 2020.
    He's always been my favorite superhero, and there's no better opportunity to dedicate a project to him.
    The scartch build will be made in plexiglass aluminum and many parts designed and printed in 3d.
    Here are some pictures of the render
  2. TodMod
    14 Dec 2018
    Thanks to all my sponor for support thi project.
    Here There are the images of the hardware that will take part in the project.
    Cooler master CPU BLOCK
    GSKILL rgb tridentz 3600 8x4
    Cooler Master sf120m
    Terabyte solution shop with those XPG m2 sx 6000 lite
    ASUS ROG Maximus II hero
    Intel Core i7-10700k lga 1200
    ASUS RTX 2080 super dual oc edition
  3. TodMod
    14 Dec 2018
    Cooler Master mve 750 gold full modular
    Cooler Master black Cable extension kit
    Coler Master Rgb controller
  4. Sa mod pc design
    Sa mod pc design Member
    7 May 2019
    Awesome bro
    TodMod likes this.
  5. TodMod
    14 Dec 2018
    greetings folks,is time start working at the bottom of the mod, starting to cut the first panels, aluminum bars and then I start printing the first angles that attached to the panels ecalla aluminum bars will serve to give stability to the entire structure.
    And after design the psu support i I'm starting to print this too.
    PSU COVER REALIZATION:
    After printing and finishing the central hooks, completing the 2 plexiglass panels and creating the new batman logos, we go to assemble everything. The result is more than satisfactory. What do you think Of the final result?
    Cheapskate likes this.
  6. TodMod
    14 Dec 2018
    the custyom batman comb are ready
    in the meantime I dedicate to the realization of the front panel.
    So after cutting the 2 panels will then be superimposed, iproceed to different phases of Painting and wrapping. and 3d print to realize the bracket to fix it.
    And finally the new batman logo is realized that Will be applied in the high prte of the panel
    now it is only necessary to make the frame of the panel but the most of the work is done
