Scratch Build – Complete BATMAN THE DARK KNIGHT
Discussion in 'Project Logs' started by TodMod, 23 Dec 2020.
  1. TodMod
    TodMod Minimodder
    14 Dec 2018
    Ahahahahahha
    Thanks so mutch I appreciate it
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Really good job. I'm living the rear panel of you build ! Congrats :thumb:
  3. TodMod
    TodMod Minimodder
    14 Dec 2018
    thank you very much, it is already the second mod in which I try to make the back of the case an integral part of the mod, thanks again
  4. Nexaner7
    Nexaner7 What's a Dremel?
    4 Feb 2021
    Wow, that build looks amazing!
    Is the motherboard tray plexi as well?
    TodMod likes this.
  5. TodMod
    TodMod Minimodder
    14 Dec 2018
    Thank you so much!! :happy:
    Yes the motherboard tray is in plex, Worked with laser engraver :dremel:
  6. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    Nice Work :) What kind of color did you use for the mirror effect on the plexi?
    TodMod likes this.
  7. TodMod
    TodMod Minimodder
    14 Dec 2018
    thanks so mutch!!!
    I used mirrored plexiglass, but you can also find adhesive films on the market that give the same effect
  8. Yargen
    1 Aug 2020
    Thanks a lot, I didn´t know that there was mirrored plexi :jawdrop: This makes things so much easier :D
  9. TodMod
    TodMod Minimodder
    14 Dec 2018
    [QUOTE = "Yargen, post: 4873598, member: 893113"] Grazie mille, non sapevo che ci fosse plexi specchiato : mascella:Questo rende le cose molto più facili : D[/ QUOTE]
    nessun problema, è un piacere aiutare, il bello è che è disponibile anche in diversi colori riflettenti:sorriso:
  10. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Awesome tod
    TodMod likes this.
  11. TodMod
    TodMod Minimodder
    14 Dec 2018
    Thx bro❤️
    Sa mod pc design likes this.
  12. MADPC
    MADPC Minimodder
    10 May 2020
    black is the new orange :) good work
    TodMod likes this.
  13. TodMod
    TodMod Minimodder
    14 Dec 2018
    thanks dude,is always one of my favorite colors!!!
    in this case the color was dictated by the dark knight anyway:grin::grin:
