This can probably be answered in one post. Would it make any difference if I were to run my wires like this, should I have the toggle switch out the positive or negative wire? or is it a bad idea all together. just double checking On the left would be the plug that goes to the charger, which would not be in use at the same as my speakers. and I already used the search btw.
Positive or negative would work - it does not matter. I am assuming the common is the battery and it is either being charged by the power supply or being utilized by the speaker.
