Scratch Build – In Progress Battle Dragon Bag - Update#30 - 9/4/12
Discussion in 'Project Logs' started by Gentleman_Dingo, 30 Sep 2011.
  1. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Yeah, I thought the same thing. After I took that picture, I remounted the modder's mesh between the frame and the fan for that very reason. It bumps the radiator out a tiny bit but there was a little room to spare inside.
    Nice catch though.
    I wish there was a way for me to have that piece showing out of the case. Unfortunately, when I put the case in the base it's facing the bottom (or top) of the case. It would either get banged and scratched up or interfere with the carrying handle and straps.
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I LOOOVE That Window etch, Killa job dude! :D:thumb:
  3. peteski
    peteski long live the pc
    8 Jun 2011
    looking sweet so far mate keep up the good work :rock: :rock: :rock:
  4. Gentleman_Dingo
    30 Aug 2007
    Update #12: IT’S UPDATE TIME!!!
    Excuses:
    New Job
    New Job with Holidays = Busy
    Holidays
    Holidays with Friends and Relatives = Busy
    Planning and preparing and spinning my wheels while motivating our webdev for the Emerald City LAN = kind of busy? I’m sure Big Red’s will scoff at that one. ;)
    Apologies:
    Sorry I’ve been “absent” with my updates. I’m noticing that I do quite a bit more modding work when I’m unemployed or under-employed. I’ve been doing micro work here and there but constantly working on my case.
    I also have to apologize that I haven’t taken as many pictures of my work and a couple are blurry. I’ll probably be looking at getting a new camera at the end of this project.
    How I will make it up to you:
    This update will be filled with content (18 pictures) and will probably cause you to wear out your scroll wheel.
    I will be turning my slowness into your benefit. I’ve done parts orders from three different modding online retail stores (and received free parts from a fourth) and will be posting an opinion/review article in the near future (the article will be vetted and hosted at DeviceUnknown.com). The article should be completed and sent to the editor by Friday.
    Now, onto the update and let’s start with some of the goodies!
    My package from Xoxide.com arrived! Contents: two strips of LEDs and a remote switching controller. I’ve never used any of the premade LED strips so this is a bit a lazy experiment. I could have gotten a bunch of LEDs off of Ebay, calculated my load and soldered in the wires for a fraction of the price but I wanted to see if the convenience was worth the price. The remote switch is for me. I like gadgets.
    My package from FrozenCPU.com arrived! Contents: two Vandal Switches and two red 8” Cold Cathode Ray Tubes. The switches are just plain cool looking. They’re fairly easy to wire up and give a particular style and look to the case. The CCRTs will be used to light the etched panels and give an ambient red light to the inside of the case.
    I got a sweet holiday present from my mother! Content: One awesome stand-up drill press. I technically didn’t get this present until the 6th of January (and excitedly assembled that same day). But it’s just too awesome of a gift not to mention. And yes, I tested it. It works effortlessly. However, I’ve already broken one drill bit playing around with it. I have to learn to gauge my pressure/strength better with the drill press. *giggles like an excite little school girl*
    I also get a bunch of bits with some of my holiday money! Contents: stuff.
    My main goal this holiday was to get the skeleton completed. I got pretty far but still have to do the mounting bracket for the video card and the HDDs/SSDs (one piece for both parts). I decided to raise the mother board and PSU mounts so I could better manage my wires. So I installed risers for the mounting plates:
    After further inspection, I decided to redo my forward plate. One of the things I’m finally starting to figure out is how you cut your aluminum will often determine how long you have to spend cleaning up the part. Bad cut = many days filing and sanding. Good cut = many hours filling and sanding. I’m starting to assess my pieces by figuring out if it’s quicker and cheaper to just scrap a piece of aluminum and cut it properly or spend the many hours filing an under-cut piece to perfection or correcting an over-cut piece to acceptable point.
    Next I designed cut my reservoir and pump mount:
    Some of you might call me a modding noob for this, but working with aluminum is a discovery process for me. I just figured out you tap from the opposite side and still be able to insert screw on the intended side. It saved me a lot of awkward tapping and creative drilling.
    Then I attached all of the pieces with temporary screws. Does anyone else do this? I find that I like to use beat up screws to hold it in place as I evaluate placing and while I determine if I’m going to recess a screw.
    Next I worked on increasing the screw size and recessing all of the screws on the top, front and bottom panels…. And apparently too much schnapps or mulled mead leads to dead taps. Fortunately I didn’t screw up the panel and was able to remove the broke tap with no real damage.
    Finally (for this update), I began working on the back panel:
    So… what’s next? Well I already have a bunch of work ready for this next update. I’m excited to utilize my new drill press. I have an ordered package coming in from Performance-PCS.com. I purchased and received a 2GB Radeon HD 6950. So I’ll include my upgrading the 6950 bios to a 6970 bios in this worklog. That’s modding right? I also received some exciting news from a new sponsor. Plenty of content and much more to come!
    (and I promise I won’t leave you hanging so long next time)
    Thanks for reading!!
  5. LazyMan
    LazyMan What's a Dremel?
    9 May 2010
    Very nice bro...looking forward to more updates.
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    You gotta love all those modding presents and purchases ;PPPP Our toys for sure!!! Mod on man I am watching!!! :)
  7. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    Looks awesome! Also, let me know if you're going to order some more stuff, I need more atx crimps.
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice project. I like dragons. ;)
  9. Gentleman_Dingo
    30 Aug 2007
    Thank you!
    Nice, always a pleasure sir. (and you were one of my votes for the MOTY) But don't tell anyone.
    Of course! NW Modders ROCK! Are you going to our LAN Party this March? Reg is up!
    http://emeraldcitylan.com/
    Sweet! Croatia! This is one of the best things about bit-tech. You get to meet people from all over the world! Thank you!
  10. Gentleman_Dingo
    30 Aug 2007
    Update #13: The unlucky update?
    This update I have a great announcement! The reviewing website DeviceUnknown.com has been gracious enough to provide me with a HD 6970 EK waterblock and back plate!
    This water block provides me with both a challenge and a reassurance. The challenge is that I’ll be suspending the water block upside down. Now that might seem so challenging but when you think how a GPU water block works you might see it differently. The reassurance comes from knowing the GPU will be cool after I’ve upgraded my HD 6950 to a 6970. When I bought this video card I did so for two reasons. One, it has a plate that can be easily modded into a mounting bracket. Two, the Radeon HD 6950 with 2GB can be BIOS flashed to a 6970. The process was simple enough.
    For step by step guide I followed this template: http://www.overclock.net/t/942034/how-to-flash-6950-to-6970-guide
    Basically, I downloaded ATIWinFlash, downloaded a 6970 BIOS, flipped the BIOS switch on my video card, flashed the BIOS and then reinstalled the drivers. Here’s the before and after on my videocard. It works like a charm.
    I’ve also received the first of two orders from Performance-PCS! My water-cooling glands are salivating? Does that even make sense?
    Any rate I’ve started on the back panel as well. This is where a CNC plasma cutter would come in incredibly handy.
    It’s not going as easy as I would have hoped for… there are some parts that I’ll have to either repair or decide to refabricate. I’m still thinking about this one. Attila! HOW DO YOU MAKE IT LOOK SO EASY!!! YOU GLORIOUS *******!!!
    Two Thank You Notes:
    First, I won a N580GTX Lightning Xtreme Edition video card and a Z68A-GD80 G3 from a MSI contest. Thank you very much. If my gaming doesn’t improve after this… then it’s the lag… yeah, that’s the ticket.
    Secondly, I’d like to thank Robert Dailey at DeviceUnknown.com for providing me the water block for this case and for giving me the opportunity to try my hand at writing. Feel free to take a look at my first foray into the online writing world see if my review on Online Modding Part eTailors sparks any interest or conversation.
    http://deviceunknown.com/?p=794
    Once again, thanks for reading and comment away!
    weatherdown likes this.
  11. Gentleman_Dingo
    30 Aug 2007
    Update #14: The repeat update.
    As part of my hobby I’ve been working on writing some article for DeviceUnknown.com. It has been a lot of fun. Yesterday, I had the privilege of chatting to Bill Owen, the famous modder of MNPCTech.com. While I won’t give away the whole course of the interview in my update (you’ll have to wait and read the article) I will say that he reminded me of two main things that keep me interested and excited about modding: learning and craftsmanship.
    Learning:
    I’ll admit I don’t know nearly as much as most modders out there. I still consider myself new to the scene and new to modding. I’m sure there’s several people out there that can tell me exactly what drill bit to use with a 1/2 inch tap that a 3/8 th inch water cooling fitting will fit snugly into… But I don’t, so I play. I call it play because this is how I have fun. I figure it out like it’s a puzzle that I want to solve. Basically, I do little things like this to remind me of certain parts of my puzzle:
    I’ll be stopping by the hardware store to get a drill bit tonight. It might be the wrong one. But I don’t care. You learn more from your mistakes than you do from your successes.
    Craftmanship:
    The title of this update is all about this section. While I was working my aluminum with the jigsaw, attacking the design with as much precision as a butcher cutting a prime steak only to grind it into hamburger patties, I ended up breaking off three pieces of the design. I suppose I could have fixed it. But I know that when it was done, I’d be able to lean in and see the flaws just under the paint, mocking me. So I decided to recreate the back panel and figure out a better way to do it. I want it an whole continuous part with smooth edges and hard lines.
    First I copied the shape and overlapped the edges so that it fit with the frame.
    Next, I created four screw holes over both the old and new pieces. Then I put the old piece over the new piece to make exact placements of the existing screw holes.
    Here, I measured and placed the TTeSport Dragon design on the panel.
    I etched the lines into the metal in case I wiped away my lines while I was cutting the metal. I also circled the areas that I had problems with last time so I knew to be sensitive with how much stress or pressure I put in these spots.
    Now, it began prepping my metal with drilled holes so that I could fit my jigsaw blade into the metal. I put a hole at every turn or angel so that I could cut lines as straight as possible.
    And then I went crazy… I just kept drilling holes. My wife begged me to stop. But I couldn’t. I just kept drilling. I can still hear the distant sound of drill press calling me….
    In other news, two more packages arrived: my second shipment of Bitspower fittings and some nice red acrylic for the back panel!
    That’s it for now! Stay tuned more to come this week!
    Thanks for reading!
  12. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks awesome. Please,continue uploading more pics. :D
  13. Sutura
    Sutura What's a Dremel?
    23 May 2011
    Hi all. I must admit when I saw this project the first day it was published, I was quite skeptical. I thought the idea was lame and the guy is just making a "dream" build, i.e one that will never get finished. Well, quite some time after, I type what the other people said: this is coming together nicely. Mod on!
  14. Gentleman_Dingo
    30 Aug 2007
    Thank you sir!
    I think modding is like painting or drawing. You can work on it forever and still never get it completely like you want. But there comes a time when you have to step passed a part and continue with the rest of the case in order to complete the case. I like finishing things as much as I like thinking up new ideas. I will get this case finished. It's my own personal goal.
  15. Cheapskate
    13 May 2007
    I'm beginning to think the bag will be the least impressive component.
  16. Gentleman_Dingo
    30 Aug 2007
    soooo... more LEDs on the bag? ;) :cooldude:
  17. Gentleman_Dingo
    30 Aug 2007
    My prize from winning http://deviceunknown.com 's first drawing arrived!
    Yeaaaaaah baby. I got it and I'm going stick it somewhere inappropriate...
    ...like in my unfinished Battle Dragon Bag case to make sure it works where I want to place it. That's ok, right?
  18. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Looking good! :thumb:
    Did Bill mention my amazing modding skills when you interviewed him, or did he forget? :lol:
    Can't wait to read the article! :)
  19. Gentleman_Dingo
    30 Aug 2007
    Actually we did talk about you. He said that you were tired of your motorcycle and wanted to give it to me? ;) Speaking of interviews, I should have some questions sent to you by this weekend.
    mnpctech likes this.
  20. mnpctech
    21 Apr 2003
    Lookin good dude! and You caught that Ice-Dragon-Cooling added Mayhems dye, for the Blood-like fluid?
    I did, which caused the Interview to span over 2 days :D
