Windows BAttleField 2142 !!! Crazy ???
Discussion in 'Gaming' started by ComputerKing, 12 Dec 2006.
Thread Status:
Not open for further replies.
  1. ComputerKing
    8 Sep 2006
    Hello I just Shacked !! THE battlefield Dont Want Me long In At This time !!!
    Why This the first Time It happen From 2 Days ( when I bought The Game )
    Bf2142 v 1.6 Online DvD ???
    What The Problem thanks
    Edit "
  2. Springs
    Springs Boing boing
    29 Aug 2004
    can you access the internet?
    can bf2142 access the internet? have you got a firewall and allowed bf to passthrough and lissten to the ports it needs?
  3. ComputerKing
    8 Sep 2006
    No firewall and Yeah The Internet Acces But bf2142 Dont Acceess
    What To do
  4. DougEdey
    5 Jul 2005
    How are you connecting to the internet? Do you have a router or just a modem?
  5. section8
    section8 What's a Dremel?
    19 Aug 2006
    Where are you from.... I had to re-read the post a few times before I understood it... Either that or you are incredibly rude!
  6. Springs
    Springs Boing boing
    29 Aug 2004
    how many times have you tried and either got through or not.... it might be EA's server being bogged down by everyone else trying to access it...
  7. [stuart]
    [stuart] What's a Dremel?
    7 Aug 2006
    The EA 2142 master servers go down around this time every Tuesday in Australia for maintenance, dont know about your timezone, but Tuesday evenings are generally the maintenance times here. Go do something else for a few hours and they should be fine then.
  8. ComputerKing
    8 Sep 2006
    My Time Zone +4 GMT - london :D
    YEah I just Tryied It Now AND IT WORKED , On this sec it workes !!!!
    BUT I GET OTHER PORBLME IN THE GAME
    WHEN I GO TO WINDOWS AND GO BACK TO THE GAME I GET BLACK SCREEN AND THE GAME LAG
    mean when i prees ( alt + tab ) to do some thing When I back Black Screen And The game Lag !!!
    So what TO do
  9. Guest-16
    Guest-16 Guest
    Because windows doesn't support tabbing in and out of the game like that. DirectX isnt made for it. Also it is an EA game so the fact it even WORKS normally is a miracle.
  10. ComputerKing
    8 Sep 2006
    But Need FOr Speed Carbon Work tab in and out !! why this one not !!!!
  11. Guest-16
    Guest-16 Guest
    The games are built differently. BF has always had problems.
  12. ComputerKing
    8 Sep 2006
    sO what the fix for it :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  13. DougEdey
    5 Jul 2005
    There is no fix for it. Systems were not built to support minimizing 3D applications you'll just have to not alt-tab out of a game.
    PS: Please can you a) Reduce the amount of emoticons you use
    b) Reduce the amount of punctuation you use.
    It helps to keep us calm enough to help you.
  14. ComputerKing
    8 Sep 2006
    OK Sorry But Is So mad About The VGA :wallbash:
    Ok any Ways Thanks
    Damit Game :duh: :duh:
  15. Glue
    Glue What's a Dremel?
    27 Oct 2006
    if you have ENOUGH RAM YOu CAN MINIMIZE IT PRETTY FAST, BUT THE GAME STILL SUCKS TECHNICALLY AND FROM A GAMERS POINT OF VIEW!!!!!!!!!!!!!!!!!!! :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
    the HIGHER your GRAPHIC SETTINGS the LONGER IT WILL TAKE TO MINIMIZE!!!!!!!!!!! :duh: :duh: :duh: :duh: :duh: :duh:
  16. ComputerKing
    8 Sep 2006
    The Speed of MINIMIZE take less than 1 sec this not the problme
    I have 2gb 800 mhz and 1950xtx 650/2000 all in high
    when i back black screen and the game lag in black screen
    SO If you know any thing say
    :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  17. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    HoW aBoUt YoU JuSt DoN't MiNiMiZe iT, WhY Do You NeeD To AnYwAy :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  18. ComputerKing
    8 Sep 2006
    To show the music and to check bit-tech.net if there replay for me or not
    lol my wall will broke becasue of this :wallbash:
  19. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Just get a second computer?
  20. acron^
    acron^ ePeen++;
    15 Oct 2001
    Alt-Tab support is down to the programming and can be handled with ease if implemented correctly. Because DICE are rubbish, it's not surprising their games do nothing right.
Thread Status:
