Hardware Battlefield 3 Performance Analysis
Discussion in 'Article Discussion' started by arcticstoat, 10 Nov 2011.
  1. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    Currently playing on medium settings at 1080p with a C2Q Q9400 overclocked to 3.2GHz and a GTX 260+
    Plays well. Don't know what all the fuss was.
  2. LedHed
    LedHed What's a Dremel?
    13 Jun 2010
    After reading this in the conclusion:
    We’ve also been able to put some performance rumours to rest. As the identical results of the HD 6950 2GB and 1GB show, simply throwing more graphics memory at BF3 doesn't improve performance. Instead, it gobbles up extra GPU resources and higher clock speeds, which would explain the reports of BF3 pushing graphics cards so hard. It certainly makes overclocking your GPU worth considering, though, especially as all the results in this article are based on the cards running at their stock clock speeds. When you consider that a GTX 560 Ti 1GB will happily accept an 80MHz (10 per cent) core frequency overclock, it’s well worth seeing what you can squeeze out of it. "
    It really makes me wonder if BitTech is monitoring system resource usage. I get 1300Mb-1480Mb VRAM usage between loading and playing, without over 1Gb of VRAM my card would be experiencing constant hiccups. I find it hard to believe that Bit-Tech missed this when they based a lot of the conclusion around it. I know multiple guys that had SLI 560s that traded up to a GTX 580 3Gb due to frame drop with only 1Gb VRAM @ 1920x1080+
    One thing people need to keep in mind is your computer won't show a game using 1.4Gb if you only have a 1Gb card. The only thing you know is you have a problem with game performance which can come from multiple things.
  3. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Good question and one I'd like a definitive answer to. From what I understand, the 4890 pitches over a 5770 but under a 6850. At 1920x1080, I'm going to be looking at high with 0xaa giving 30ish fps.
    As an aside: have we witnessed the quiet, unlamented death of physX in 2011?
    immoral likes this.
  4. braincake
    braincake What's a Dremel?
    21 Apr 2011
    yeah, the ingame graph shows cpu use spiking up occasionally and its always above gpu usage, guess i need a quad core
  5. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Exactly, and insufficient VRAM is not a problem that would necessarily show up in a benchmark either. It may not manifest itself as a dip in average or (even minimum) frame rates on a short benchmark. Rather it would highlight itself as infrequent (but annoying) stutters as textures are swapped out - for example when moving from one part of the game world to another.
  6. Thursfield
    Thursfield What's a Dremel?
    13 Nov 2011
    Where are the AMD CPU's in this test? Would be interesting to see how the AMD CPU:s compare to Intel in this test. Not a biggy but it would be nice if it was included! At least for us AMD users.
  7. kieran_read
    kieran_read What's a Dremel?
    15 Aug 2008
    Out of interest what would my 4870x2 be akin to?
    i don't plan on upgrading it any time soon can still play most things on high...
  8. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    Just a question, the depth for the GPU's is most fantastic shows up a lot, I am sure that people can tweak their levels to boost performance accordingly - I'd love to know the effect an overclocked CPU would have on framerates - lets say the current testbed overclocked to 4ghz.... do we see a measureable improvement?
  9. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    High settings, id imagine somewhere around a gtx470 as i know its a bit more powerful than a gtx 460.
  10. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Strange then that with my gtx460 the game sets itself to high, and I haven't really noticed any lag (1680x1050). Don't think i'll upgrade just yet.
  11. chrismarkham1982
    1 Apr 2010
    OC that 460 and you'l have high pre-set with 2 x AA @ 1920 x 1080, i know I did.
  12. Prowler_88
    Prowler_88 What's a Dremel?
    28 Jun 2009
    I've got eveything on Ultra, 4xMSAA, Post AA all the way up, and it runs smoothly.
    Constantly saying we need dual GPU isn't rue, just buy an overclockable card: My 580 is up to 940MHz, with the memory and shader oc'd too. My frame rate never drops below 50, which to my eyes is pretty smooth, and certainly doesn't hinder me from getting decent scores in.
    Anyone want to join me in a game, I'm Black_bart_blues (any iron maiden fans will notice my naming pattern :)
  13. Prowler_88
    28 Jun 2009
    Also, anybody noticed how the game looks much better post-patch?
  14. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    Not played post patch yet (skyrim got me hooked) but interesting that it looks better as it looks pretty good anyway!
  15. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    I've not really noticed.
  16. Ergath
    Ergath Giant Zombie Pigeon Photographer
    6 May 2009
    My 5850 manages pretty well on a custom setting that amounts to High. I'm certainly getting well over 25fps minimum.
    Has anyone tested how much the Field of View affects performance?
Tags: Add Tags
