News Battlefield 3 recommended specs only good for medium settings
Discussion in 'Article Discussion' started by arcticstoat, 23 Sep 2011.
  1. woods
    woods What's a Dremel?
    27 Apr 2010
    My i750 Hd5850 handled crysis 2 pretty well with the dx 11 and hi res textures, but i,m not starting a new build until I see Ivy Bridge series 7 amd amd 680 nvidia, I'm gonna stick with my two year old sytem to the beging of next year, and hope it runs ok on medium settings
  2. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    If you're getting happy at teh fact this needs £600 worth of graphics to play well, then you really need to take a look at yourself.
    You wouldn't pay hundreds for the game, so why pay hundreds for a card to play the game slightly prettier?
  3. technogiant
    technogiant What's a Dremel?
    2 May 2009
    It's not all about the gpu either.....BFBC2 which used the frostbite1 engine was cpu heavy.
    From what I saw on the Alpha BF3 release the Frostbite2 engine is also cpu heavy.
    All four cores of my Q6600 oced to 3.5GHz were maxed out by the game which at that stage was only able to utilize one gpu of my sli set up....there will be more cpu load to feed two gpu's.
    I know I need a cpu upgrade but a Q6600 at 3.5Ghz is not an insignificant cpu in gaming terms.
  4. technogiant
    2 May 2009
    Not only the consoles, it's about time Microsoft and all the hardware people got together and sorted things out on the pc so that developers can get "closer to the metal" like they can on the consoles.
    Like John Carmack said.....its absurd how such powerful pc's do not give the increase in performance that would be expected......but then again perhaps its not in the hardware developers interests to improve things, they would rather keep us on the upgrade cycle.
  5. TAG
    TAG What's a Dremel?
    7 Aug 2002
    How the hell am I supposed to run this @ 6000x1200 ?
    :wallbash:
  6. Ayrto
    Ayrto What's a Dremel?
    20 Jun 2007
    I can think of worse dilemmas to have.
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'll still try it on ultra settings @ 1080p to see if it's at all chuggy :D.
  8. Zorndar
    Zorndar What's a Dremel?
    26 May 2008
    Lets see if my 5870 can handle it on mid settings, perhaps I wait to upgrade until the 580´s are a bit cheaper.
  9. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
  10. leslie
    leslie Just me!
    19 May 2009
    You do not need a $600 card to get there.
    The settings posted are enough to get you into high/ultra at 1080.
    BT needs to pull this article, it's wrong.
  11. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Unless it's true :S
  12. tristanperry
    tristanperry Minimodder
    22 May 2010
  13. Paddy4929
    Paddy4929 NangO-Gamer
    24 Apr 2009
    2 x 570's in SLI, i7 @4ghz i'll give ultra a go!
  14. Zendax
    Zendax What's a Dremel?
    2 Jun 2011
    The idea that some people have that Recommended should mean "all detailed maxed" is a bit ridiculous.
    Historically, Minimum settings are the bare minimum you need for the game to be playable at any settings.
    Recommended is the computer you need to have a good experience. The game will look good and play well, and you may not even know what you're missing.
    Ultra settings are usually more for flexing graphical muscle and benchmarks than anything else. Doom 3 was the worst in this regard. The only difference between high and ultra was the latter used uncompressed textures. Even in screenshot comparisons there was no perceptible difference, besides doubling the amount of graphics RAM needed.
  15. modfx
    modfx Loft Gremlin
    11 Feb 2010
    ^ this
  16. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    Same here.
    Hopefully my 750 and 460 will be capable of 'high' settings.
    Then I can get into all the ultra pretty stuff with my Ivy Bride / 670 rig I will build in March/April. :D
  17. luisnhamue
    luisnhamue What's a Dremel?
    25 Sep 2011
    This kind of games that push hardware to its max, is nice because put us apart from the console guys. But damn, having to buy 2*580GTX is too much just to play a game. I guess this game is just for the next crop of GPU's. but anyway i will play it with my HD 6950.
  18. leslie
    leslie Just me!
    19 May 2009
    I can assure you, it isn't.
  19. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Hahahahaha.
    How to make your game the most eagerly anticipated PC release of the year? Tell people they can't run it.
    I call BS on 580 SLI, unless he's talking about 2,560 x 1,600 4x AA 16x AF.
  20. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Surely the article should be updated to correct the statement and edit it to say that the recommended specs are indeed for high, rather than medium. Misleading otherwise.
Tags: Add Tags
