Reviews Be Quiet! Dark Base 700 Review
Discussion in 'Article Discussion' started by bit-tech, 14 Nov 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. RedFlames
    23 Apr 2009
    Guessing that's meant to be 'There are no dedicated mounting points for pumps or reservoirs, which is a shame,'
    Or are you so eager to mod it you're disappointed that BeQuiet have done it for you.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Bit of a derp there. Thank you - now fixed.
  4. RedFlames
    23 Apr 2009
    *dons columbo style jacket* One more thing...
    Did you/can you test it in it's inverted layout [and or with the GPU on that 90-degree bracket], just curious if it actually makes any difference...
  5. Dogbert666
    17 Jan 2010
    Don't have the right-angled bracket to test with. I shall do an inverted test tomorrow, if there's time. Are you interested in maybe buying it? I'll try either way, but I'm more likely to find the time if I know your money may be on the line!
  6. RedFlames
    23 Apr 2009
    More to satisfy my curiosity than anything else, if time doesn't allow then fair enough.
    Plus BeQuiet make a point of making a case that lets you do funky things with the layout... only for precisely none of the reviews [that I've seen] to test any of said configurations, bar the 'normal' one. Not having a pop at you/bit-tech, just annoyed that no-one has given any of the alternate configs a go for whatever reason.
  7. Dogbert666
    17 Jan 2010
    Did it yesterday :)
    At full performance, full speed, CPU went to 47 delta. GPU at 49 delta though, so that's the trade-off. Airflow is more direct for CPU, but less reaches GPU, so makes sense.
    Will update article when I get a moment.
    RedFlames likes this.
Tags: Add Tags
