Hardware Be Quiet! Dark Power Pro 650W
Discussion in 'Article Discussion' started by Tim S, 29 Jul 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    looks like a very solid PSU
    question tho i consistently find the PSU to be the noisiest thing in myu machines is the FDB system really that good is it so quiet as to be unnoticable after about 1m.
    i have bought so called siilent psu's in the past only to be dissapointed
  3. Guest-23315
    Guest-23315 Guest
    It does look very nice indeed!
  4. Guest-16
    Guest-16 Guest
    It really is difficult to tell it's running sometimes. At 50% load I had to put my ear directly over it. I certainly don't use the term "silent" unless it's actually inaudible.
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    offer?
    :D Glad to read this, it's amazing how much it gets used when it's just a lie.
  6. The boy 4rm oz
    10 Apr 2008
    I like those fan connectors, they could have been sleeved though.
  7. Guest-23315
    Guest-23315 Guest
    Rich, how quiet are these units compared with the current Corsair HX units running at low fan mode?
    I guess they are fairly comparable. Or at least I hope they are!
  8. Guest-16
    Guest-16 Guest
    I've not got a HX in house for comparison but Seasonic insist on using Ball Bearing fans which are quiet, but not FDB quiet.
  9. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    Looks like this is the replacement for my HX620 then :)
  10. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    You are going to replace a 600w+ psu for another 600w+ psu. This doesn't make any sense. Maybe you want to replace it for a 700w+ psu?
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    why replace the 620w Corsair Hx with thisone?
  12. The boy 4rm oz
    10 Apr 2008
    Good point.
  13. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    i bought this exact PSU a month ago, and have to say its the best purchase i made. got it for £97 delivered from tekheads.
    (im in the UK btw)
    the only thing is the warranty, but im sure pay about £20 to get it shiped and repaired and back will be worth it, IF it does go wrong. and yes the review is right, i couldnt hear a damned thing. I thought it was broken, but then my computer turned on w.o a hitch, AND it is very stable.
    for germany, they have a 48hour swap on sight service, bring there here, and it'll be amazing :)
  14. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Good review, looks like a very nice power supply, modular (yay) and a good feature set with low noise output. My only quarrel is: 4 x 12v rails... I'm lazy, give me a single 12v rail @ 54-60A and let me be :( (By that I mean another viable competitor against Corsair's and PC Power and Cooling single 12v rail line-up... the more competition, the better, and hopefully more aggressive pricing in response).
  15. shaffaaf27
    3 Jun 2008
    right im not sure how much load im pulling, but at 100% load with my E2140@3.0GHz :1.4 Vcore, 2.1Vram 1.6 VPLL 1.4 VFBST 1.05VSB 1.4VNB
    my rails (reported by everest):
    3.3V: 3.3280
    5V: 5.0160
    12V: 11.9840
  16. zaodrze244
    zaodrze244 What's a Dremel?
    29 Jul 2008
    it look's like that this psu was made by the TOPOWER for bequiet... :p
  17. hitman012
    hitman012 Minimodder
    6 May 2005
    Yeah, the supply is OEMed by Topower (as are Tagan and OCZ units) so it should be fairly reliable.
  18. StephenK
    21 Dec 2006
    I'm just doing a little upgrading and maybe have a project in mind which could use the hx. I figure if I'm ugrading bits from my existing box i might as well upgrade the psu while I'm at it but i don't need any extra power. Less noisy and more efficient is nice. Why upgrade to more power than I need just for the sake of it ? :) Or am I missing something?
  19. Guest-16
    Guest-16 Guest
    No it's FSP. They used to use Topower in old revisions.
    Jasio - I agree, but ONLY when a single 12V is done well with high quality components, otherwise it's a liability.
  20. roadrun777
    roadrun777 What's a Dremel?
    30 Jul 2008
    The fact that you did not test the noise level of this PS says volumes about your testing method.
    Is this a joke? Would people buy a silent PS for it's power ratings or how silent it is when it's being used heavily?
    I really don't take any review of a quiet products seriously unless they include some kind of db rating system, and even some audio captures at different distances.
Tags: Add Tags
