Reviews Be Quiet! Dark Rock Slim Review
Discussion in 'Article Discussion' started by bit-tech, 14 May 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Quick question re: the reviews...
    Do you run the CPU cooler fans (either PWM fans or with CPU temp DC control via m/b) with the CPU at full load @ stock to see just what speed the fan(s) get to, and therefore the noise level?
    The reason I ask is that with my new Noctua Chromax 120mm fans push/pull PWM controlled on an H55, they never get to full speed with my (admittedly low TDP) CPU under full load therefore they are absolutely silent.
    I wondering if this is a part of the test that may be missing, it would show the temperature, fan speed and noise in a "normal" usage scenario.
    Running fans at full speed when they may not actually need to may give a misleading impression, especially regarding noise (my favourrite hobby-horse).
    Thoughts?
Tags: Add Tags
