Modding Be Quiet! PC Noise Absorber Kit
Discussion in 'Article Discussion' started by Tim S, 9 Sep 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    So, If it weren't for the hole in the side of your case, do you think it would be any better?
  3. ComputerKing
    8 Sep 2006
    mm I agree with this "prevention is better than a cure" as Bit-Tech said, Because this thing make the case ugly.. And why waterproof! Who the idoit will wash his computer with water! It's useless thing really... This is my view and my thinking..
    Thanks BT for the review. ;)
  4. capnPedro
    11 Apr 2007
    there's moisture in the air. If it's not waterproof, you can get mould growing in it.
    These kits aren't totally useless. My HTPC was quiet. Real quiet; 1 Coolink SWiF-801 (7v) (9dB) and 1 Noctua NF-S12-800 (10v) (<5dB). In an attemp to get it quieter, I cut up one of the "egg crate" foam tiles you glue to walls for a recording studio or whatever and stuck in in my case. It made a noticeable difference in reducing the fan noise (or at least 'bouncing' it out the back of the case, instead of the front). It didn't affect the HDD noise, though. Different pitch/frequency I guess.
    So in my experience, the foam works. But only under limited circumstances. So, £20 is a bit much, but £4, like I paid is more like it. It looks like crap though, I wouldn't want it in a case with a window.
  5. Guest-23315
    Guest-23315 Guest
    Also, I'd actually be quite interested in some of the blue stuff.
  6. Zut
    Zut What's a Dremel?
    5 Feb 2005
    From the article...
    A new XPC eh? Can we expect a review of the SP35P2 next week then?!
  7. atanum141
    22 Jul 2004
    Fantastic exactly what ive been looking for coz the Akasa stuffs not enough and pricey.
  8. ComputerKing
    8 Sep 2006
    Oh right, :wallbash: Thanks for clear this to me :clap: :thumb:
  9. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    One day, I'll fill the hole in my Aurora with Acrylic. I rember I asked in the modding section before about Noise absorbtion foam and you basicly said the same, fans, hard drives and heatsinks first. Not for me I think.
  10. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Might be interesting to see if you can drown out HDD's in one of those zalman passive cases for a completely silent PC :)
  11. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    if nothing else it makes for a nice internal finish, might use some of this for sound deadening when I'm running on silent setting, or as an interior backdrop for the components when on display.
  12. Loggitt
    Loggitt What's a Dremel?
    9 Sep 2007
    You should have asked me about it, first. ;) I used the Akasa stuff several years ago. It did absolutely nothing to reduce noise, but made my case's inside temperature (motherboard temp) just keep rising and rising as the hours wore on. The junk absorbs heat and doesn't dissipate it out through the side of the case it's glued to. Bummer! :( Even though I have no experience with the currently reviewed product, after reading your review, I won't recommend it, nor would I use it. Like you stated (thank you), once it's on, it's on forever. Unless, of course, you like to torture yourself! LOL
  13. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    cheesecake ?
    Good product seconded by an apparently good manual.
    Interesting buy, I'd say. And I like the way it looks like when done. The Dark matting is cool !
  14. Spacecowboy92
    10 Apr 2006
    I used the ghetto elastic band mod on my harddrive. Completly silent now, exept for the rest of the computer that is.
  15. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    So how much difference did it actually make? In my computer, fans are the biggest noise producer (but thats because I have a cheap case and cheap fans and it has a window)
  16. Irvine
    Irvine What's a Dremel?
    29 Sep 2004
    I suspended my hard drive with an elastic band, and it made a HUGE difference, quite honestly. I built my latest rig for silence, and I thought it was quiet, until I later suspended the hard drive. Apparently, the hard drive vibrations carry through the case and essentially amplify them, so removing the source of the vibration will remove the case vibrations.
  17. Guest-16
    Guest-16 Guest
    TR, yes.
  18. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Just for info,
    Their PSU seems to be genuinely low-noise, modular too.
  19. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    I'd buy it.
    I'm looking to silence my pc anyways.
  20. Xir
    Xir Modder
    26 Apr 2006
    Heh...Heheh...Heheheheh-HAAAA!
    I knew the seventies were returning in furniture design, but now the nineties are returning to Bit-Tech ;-)
    1998 we spent getting dual-celeron boards to run and overclocking them and having to cool them with like 10 40-60mm fans. (yeah, we were grateful for 80mm fans back then.)
    1999 we spent soundproofing the things because they quickley became unbearable. I must've fitted about 6 cases with the stuff you show here. (or was it in 2000?)...and many others with cheaper alternatives...carpet, insulating sleeping mats, bitumen roof covering (essentially the lower 2 mm of your test mat only stickier)
    My start into modding, really ;-)
    Eventually we (I) learned, soundproofing:
    makes more heat makes more cooling makes more noise makes more soundproofing andsoonandsoon. Also makes for heavy cases (back then when to play in a network, we actually had to get together)
    Leaves 2 possibilities:
    a) Live with lower power: Noise is best canncelled out by avoiding it in the first place, this means usually avoiding dual garphicscards, 10.000rpm harddrives and overclocking.
    b) Live with decreased portability: Go for watercooling, maximum power at low noiselevel.
    Xir
Tags: Add Tags
