Reviews Be Quiet! Pure Base 500 Review
Discussion in 'Article Discussion' started by bit-tech, 17 Sep 2019.
  1. bit-tech
    bit-tech Supreme Overlord Staff Administrator
    12 Mar 2001
    Read more
  2. GeorgeK
    18 Sep 2010
    Probably because it's not live on the main site yet?
  3. Dogbert666
    Dogbert666 *Fewer Staff Administrator
    17 Jan 2010
    Update 17/09/2019: Be Quiet! has been in touch to say that it is now going to perform additional tests of its own in order to try and replicate similar results and identify where the issue might be either in general, with our sample specifically, or with our test kit/methodology. We stand by our testing and analysis at this stage, but we'll be working with them in this process and will update the article if necessary.
  4. Andy M
    Andy M What's a Dremel?
    26 Mar 2012
    It looks to me like that front fan needs the rest of the case front where it is mounted to be solid, or at least have baffle panels installed, so that it doesn't just circulate air around itself. Let's see what they come up with.
  5. Xir
    Xir Modder
    26 Apr 2006
    probably would be a lot better with the PSU mounted so that it draws from the inside of the case (good for quietness too) and a better exhausting GPU.
Tags: Add Tags
