Hardware Be Quiet! Pure Power 9 CM 600W Review
Discussion in 'Article Discussion' started by Combatus, 13 Apr 2016.
  1. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
  2. Xir
    Xir Modder
    26 Apr 2006
    Hmmm, the pricepoints in Germany are different. The Be Quiet is much cheaper than the compared ones
    The (upcoming?) non CM version shoud be 10€ cheaper still.
    be quiet! Pure Power 9 600W CM ~80€
    EVGA SuperNOVA G2 650W ~103€
    SilverStone SX600-G 600W ~110€
  3. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    Really liking the orange ring around the fan...
    ....I may or may not have initially though this was a review for a 600W PSU with a length of less than 10 centimeters. :duh: I really should stop interneting when I'm not fully awake yet :rolleyes:
  4. Deders
    Deders Modder
    14 Nov 2010
    Not sure what all this fuss over fans turning completely off is all about. Having used Be Quiet PSU's in the past I know they can be completely silent with the fan running low-medium, if not high, and that is holding my ear up to the fan.
    Even with my Corsair HX 850i, setting the fan at a silent 40% decreases the internal temp by 10c, which if the "every 10c rise in temp will half the lifespan of your components" adage is true, then I could be doubling the time my components run more efficiently,
    Same goes for graphics cards. It's actually easy to maintain a lower temperature if you have cooling applied before the temp rises. So having GPU fans set to the highest you can (whilst still maintaining silence) before you start a game will give you a huge advantage in combating any noise you might get from fans at high load.
    I know it can make sense for ~150W GPU's, but it's definitely not preferable at ~250W.
  5. rollo
    rollo Modder
    16 May 2008
    Prices in uk are so close you can get the evga one for less some days in sales
Tags: Add Tags
