Case Mod - In Progress Be Quiet S.B.800
Discussion in 'Project Logs' started by Icelander, 27 Sep 2015.
  1. Icelander
    Icelander Minimodder
    3 Mar 2015
    Thanks you Blammo :thumb:
  2. Icelander
    3 Mar 2015
    So coming up I painted the outer panels and I am half way through
    More modding has to be done to the Front and top before I put the Final coat on
    It comes in handy to hang it up inside when there is Frosty outside so I painted the panels beside the door for ventilation.
    And I used Masking Tape on those sides for detailing later on
    Next up will be some hardware from Alphacool.
    Thanks you for joining me
    ICE
  3. Icelander
    3 Mar 2015
    So I have in store 20 pictures so have fun.
    I have few pictures of watercooling products kindly provided from Alphacool.
    Secondly I Painted all the Aluminum panels and made some opening for my neat cable routing
    Well I think I let the pictures speak for themselves so here we GO ;)
    vinyl sticker on the PSU
    Alphacool nickel plexi and PWM D5 pump
    Fittings and the new Ram cooler kit... looks good.
    Front bezel just in progress, not finished :)
    Thats it for now. Stay tuned for MORE MODS By me
    ICE
  4. Icelander
    3 Mar 2015
    Ok so 2 new packages came in. 1 GPU block from my friends at Alphacool > Kindly provided.
    And at O.C,UK I bought me new sticks of 4 DDR4 2666Mhz RAM.
    So I painted the GPU block to match the overall White & Silver Theme but first the RAM shots.
    Stock pictures of the case + block & backplate
    I gave some of the fans an extra 2 coats and I am happy with how they came out .
    So all I need to begin the loop is the CPU.
    Thanks for checking me out. See you later and comment , give me a star if you feel like I earned it and be positive about what we do. To mod is Fun and keeping that spirit helps and makes room for more creativity :)
    Icelander
  5. WarBoys
    WarBoys What's a Dremel?
    25 Nov 2015
    Great start!
  6. Icelander
    3 Mar 2015
    Hi everyone. I am back after long wait for my purchase the 5820K Intel Cpu :)
    Also I started getting things ready for the plumbing.
    Some of the cables have arrived from Icemodz and I will show you more of them when the rest arrives.
    Next update will be soon as I am in the plumbing stages... Fun Fun ;)
    Thanks for coming & stay Tuned for the rest people.
    Ice
