Hardware Be Quiet! Shadow Rock TopFlow SR1 review
Discussion in 'Article Discussion' started by brumgrunt, 13 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    are there more cooler reviews still to come? you could at least round the bad / mediocre ones into one article
  3. Bungletron
    Bungletron Minimodder
    25 May 2010
    I got one of these a few months back, the installation is a pig and whilst not tall it is incredibly large, I would also advise that cramped mATX installs may also experience difficulty depending on the CPU placement of the particular board (I had to remove a case fan and a drive cage). Ideally you want to measure up the cooler orientation so it does not overhang the board which may or may not be possible.
  4. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    ... how come the lga1155 score is a .jpg while the amd score is a .gif?
Tags: Add Tags
