News Be Quiet! Shows New, Even Quieter PSU
Discussion in 'Article Discussion' started by Claave, 31 May 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Looks good, will it be better than the Corsair AX 850 is the question?
  3. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Veeeery nice indeed. Might make its way into my server.
  4. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Great stuff, using Seasonic will always get a thumbs up from me. I'd have one of their PSU's now, if I hadn't been looking for one when they were phasing out the model Bit-Tech recommended (the next model wasn't tested, when it was it wasn't great. I went for Seasonic instead :D)
  5. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    I thought all PSUs had a rubber trim these days? My Cooler Master Silent Pro 700W that I've had for over 3 years does. It also has the most gorgeous all black, flat, modular cables:
  6. NickCPC
    NickCPC Minimodder
    8 Apr 2009
    Aren't a couple of these supposed to be 80+ Platinum?
    Look forward to seeing reviews later in the year, and another +1 for the partnership with Seasonic (my X-650 is brilliant).
  7. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Any word on power efficiency?
  8. Jezcentral
    Jezcentral Minimodder
    7 Sep 2009
    Will they be restoring the post-shutdown cooling ability they jettisoned for generation P7 (I think it was)?
  9. Paul2011
    Paul2011 Minimodder
    20 Jul 2010
    very nice, have one of their psu's in my htpc and i cant fault it at all
  10. ffjason
    ffjason What's a Dremel?
    27 Jul 2009
    This has only caused my computers issues so I hope they dont.
Tags: Add Tags
