Hardware Be Quiet! Silent Base 800 Review
Discussion in 'Article Discussion' started by Combatus, 18 Nov 2014.
  1. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    The soundproofing material and little features aimed at silencing any installed computer puts this on my wish list. Love the hints of Orange and the hints of Silver - can't decide!
    Fingers crossed!
  2. mr.sh
    mr.sh FEAR
    31 Jul 2009
    I like the neat design. The color schemes are great.
    Also the rubber bracket is good idea, so I miss sound measures.
  3. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I'm disappointed, I've been really looking forward to this chassis and be Quiet! products are normally excellent. Still, I'd love to see an Matx version.
  4. ulfar
    ulfar holy s**t, i can change this?
    5 Oct 2010
    when it comes to the construction, i like the effort the put into sound dampening.
    the overall decoupling of noise sources and sacrifice of airflow.
    everything seems to be clamped down tight
    when it comes to the design, i like the squares on the side panels :dremel:
  5. oddworld
    oddworld What's a Dremel?
    18 Nov 2014
    Ilike it and would love to build in one to see what i could squize into it :D
  6. Steelez
    Steelez Minimodder
    16 Jan 2004
    The sound proofing. Having gone from an old Antec P180 to a "normal" air cooled case I can certainly notice a big difference, so that, imo, is it's best feature.
  7. fusionpower
    fusionpower What's a Dremel?
    5 Jul 2011
    Really like the black and orange, fairly subtle use of the colour.
    The anti vibration mounting is great also.
  8. MGL1992
    MGL1992 What's a Dremel?
    18 Nov 2014
    I love the fact that they have implemented there products into a case, currently using some of there fans myself ( as well as a CPU cooler) and I haven't seen better quality else where. I am imagining that the padded bits of the case will stop any annoying rattles when gaming (when things get hot ;) ).
    I also think that the colour scheme is something new, not really seen anything like that except maybe cheap imitations from knock-off brands.
    Although noise isolation isn't really that new, I'm glad they have made there way into a dominated marked, mostly by coolermaster, zalman, fractal and thermaltake but they have a fighting chance if they keep the quality up and produce some kick-ass cases. Quite like that orange and black scheme over the silver.
  9. Troglodyte
    Troglodyte What's a Dremel?
    29 Mar 2011
    I really love the side blanking plates ,gives you a bit of gpu cooling with the bonus of a dust filter; and its the same both sides so no matter what way the case is orientated it looks the same ( add to this the reversible door hinges and hey presto) . Shame about the stats .
  10. graphitone
    graphitone What's a Dremel?
    22 May 2012
  11. Troglodyte
    29 Mar 2011
    +1 All we have is a few lines in the 'Performance Analysis' . Any low noise chassis reviews need to take this into consideration , from what I remember this used to be the case (unintentional lol).
  12. 63jax
    63jax What's a Dremel?
    18 Jan 2011
    well...i appreciate the silence more that any feature of the case, of course the cooling is important but for me personally the silence comes first.
  13. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    It's gotta be the sound deadening for me and the inclusion of good fans as standard with a case. Also, the black orange thing it's got going on is quite pretty (not just outside but with the cable management holes and drive adapters)....aaaand it reminds me of playing Half Life: Uplink for the first time again.
    I wonder if the less than good thermal performance good be improved by swapping in some slightly more pokey fans like something from Noctua, the spec of the Pure Wings 2 units suggest they flow a good 20-40cfm less than equivalent sized fans. I know they're meant to be quiet but the case is going to help you out if you use more noisy fans anyway. I was also thinking about watercooling and just going for quick disconnects and an external radiator like the XSPC AX series with the optional stand for them.
  14. Wazaabi
    Wazaabi What's a Dremel?
    11 Mar 2011
    I like the design - spacious yet slim, stylish and fresh.
  15. ripmax
    ripmax Minimodder
    8 Apr 2010
    I really like the sound dampening, quietness is an important feature for me. I am also a sucker for black and orange.
  16. hobbs182
    hobbs182 What's a Dremel?
    31 Oct 2014
    Plenty of space and made by be quiet nom
    Looks very sleek from the front even with the wild orange,
    Very interesting!
    Sent from my Nexus 5
  17. ginettag4
    ginettag4 What's a Dremel?
    18 Nov 2014
    I like how they have went for a quiet setup rather than one filled with areas for radiators which, for me is useless.
  18. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    It's alright, like it much more in the all black!
    Would really like to see it in a m-itx form though, small is sexy :D
  19. kieran_read
    kieran_read What's a Dremel?
    15 Aug 2008
    Considering my case is so old, I really like that it has dust filters... and noise filters, big fan of colour combination out of the 3 colours that would be my choice XD.
  20. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    No thanks, not even for free.
Tags: Add Tags
