Modding Beautiful water cooled rig
Discussion in 'Modding' started by sladesurfer, 11 Dec 2007.
  1. sladesurfer
    sladesurfer What's a Dremel?
    14 Jul 2006
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    damn that is nice, goes well with the trend of less is more.
  3. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    At first I thought it was a company's third-party product, but it's just a modders work of art!
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    very clean! what's the purpose of two T's in the WC loop though? it seems like the t splits to the GFX and cpu loop and to the top radiator, however that doesn't seem to make any sense?
  5. JoeJones
    JoeJones What's a Dremel?
    24 Nov 2007
    I think the bottom T is for a drain point. The cabling on this makes it really...very tidy, sharp and those SATA cables are pretty darn nice.
  6. naokaji
    naokaji whatever
    8 Dec 2006
    the upper T is for a fill port and the lower one for a drain port as i see it.
  7. francisl1420
    francisl1420 What's a Dremel?
    23 Jul 2007
    That elbow straight out of the pump must kill flow rates.
  8. JesterQ
    JesterQ What's a Dremel?
    15 Jul 2004
    looks really slick .. :D
  9. sladesurfer
    14 Jul 2006
    Anybody else notice the 24 pin connector? each wire sleeved individually :eeek:
  10. radodrill
    radodrill Resident EI
    14 Mar 2006
    I'm not sure if each wire is individually sleeved; but it's certainly split into a number of sleeved groups.
  11. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    Gah, freaking internet, now I want to go spend $300 on a WC setup. :wallbash:
  12. keir
    keir S p i t F i r e
    5 Oct 2003
    Very nice!
  13. Major
    Major Guest
    Very very nice!
    Is that case for sale anywhere? or is it custom made as well?
    Edit: as it's a modded TJ07
  14. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    loving the more is less style looks like an stock case. but it's not, i want one just to sit on my desk and stare at :X sooo purdy.
  15. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    lol sladesurfer you're pimping this mod in more forums than SiNiSon is.
  16. sladesurfer
    14 Jul 2006
    gotta give credit where credit is due :rock:
  17. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    That is one sweet looking case, but for some reason I find the SATA cables the most attractive part, I AM SUCH A FREAK! (Obvious some sort of SATA fetish going on here)
  18. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    i guess hose clamps are an optional extra?
  19. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    thant exactly what i thought, its very pretty tho
    surely there would be a fair amount of upwards pressure on the top fillport also
  20. radodrill
    14 Mar 2006
    When using 7/16" tubing on 1/2" barbs, you can omit the hose clamps; with 1/2" tubing on 1/2" barbs I just use zip-ties
