BeerNulle's Beer Server, updated 16-03-2004
Discussion in 'Project Logs' started by BeerNulle, 13 Mar 2004.
  1. BeerNulle
    BeerNulle What's a Dremel?
    20 Nov 2003
    The time has come. The King is almost dead, long live the up and coming Beer Server(tm).
    My beloved server has to die. It is buttugly, and problems are arising.
    After adding yet another HDD, temps are so high I'm concerned for my hardware. The SMART feature of my HDD's are reporting temps around 50-55 degrees Celsius and my passively cooled P3-450 is ~60 degrees :rolleyes:
    So, the King has to die:
    The original colormod of this one was made in 1997 :D
    The inside of the King:
    As you can see, there is no room for fans or anything. And the case is so crowded, that I don't even want to think about modding it :sigh:
    What are my plans then?
    Move the MB, PSU & HDD's to a new custombuild case.
    Rip anything unnecesarry out of there.
    - No cd-writer (and therefore no Adaptec 2940 taking up a PCI-slot)
    - No floppy
    - No soundcard
    - No permanent DVD-drive (if I need one, I will open the case and attach it. But almost anything will get there over LAN)
    I want to make it out of wood, as I have (some) of the tools needed. And wood is relatively cheap. As this is going to be my first custombuild case, I don't plan on bying any special kind of wood, just something cheap. I'm going to paint it anyway :D
    Plans for the layout:
    - MB in one part, and PSU & HDD in another part of the case, separatet by a "wall" to make cooling most efficient.
    - 2x120 mm fan, one to cool each part of the case.
    - "Invinsible cables"
    - Windows
    - Nice colors
    Let the modding begin :thumb:
  2. toand
    toand What's a Dremel?
    17 Feb 2004
    Hey neighbour! :D
    Good luck with the project, seems promising. :thumb:
  3. Sol Badguy
    Sol Badguy What's a Dremel?
    29 Oct 2003
    iam wondering if all that is necessary? cant just add some blowholes, rounded cables, and sleeving. there seems more than enough room to me.
  4. ajack
    ajack rox
    17 Apr 2003
    90% of modding isnt necessary - its for experience and fun
    Heh you werent joking! That colour is enough to blind a man
  5. BeerNulle
    20 Nov 2003
    This is not only a question of necessity. I don't like the case anymore, so I want a new one anyway. If I build it myself, I can get it juuust the way I want it :D
  6. coorz
    coorz Miffed
    25 Apr 2003
    Aah good old days, quality AOpen case that one, very nice for it's time.
  7. Atomsk
    Atomsk What's a Dremel?
    13 Mar 2004
    What do you mean by invinsible cables?
  8. SJH
    SJH Minimodder
    24 Dec 2003
    I think he means that he will hide them from view as best he can - routing them behind the motherboard is one way of doing this.
  9. BeerNulle
    20 Nov 2003
    Yes :D
    Close, but no cigar. I have other ideas... In my plans they are almost invinsible, but lets see if my skills are as good as my ideas :worried:
  10. Cereal
    Cereal What's a Dremel?
    28 Feb 2004
    okey dokey...i need to build myself a server, but i have 2 or 3 other projects out ahead of it....
  11. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
  12. Go4t
    Go4t i
    13 Dec 2003
    Pimpmobile
  13. Cereal
    28 Feb 2004
    wow, that beer pc is awsome... i was just over there at mini-itx.com looking at those projects...and i guess i missed that one. but that thng is great!
  14. BeerNulle
    20 Nov 2003
    Sorry :D
    No, I haven't been thinking in that direction, as I want to reuse my old equipment. Nice one, though.
  15. BeerNulle
    20 Nov 2003
    Update time !!! :rock:
    Yesterday I went to the local DIY centre to get some wood. I ended up with this nice sheet of (Danish word: Spånplade):
    Its about 125x150 cm.
    After a lot of sawing, I ended up with these nice components:
    And now, for the very first time... A look at the design of the Beer Server(tm):
    On the left I plan to install the MB and on the right I want to install the HDD's and the PSU
    The measurements of the case are:
    Widht: 54 x 37 cm
    Height : 22 cm
    So, what am I going to do next? Sanding, sanding, sanding. When everything is nice and smooth, I will begin measuring the exact location of the MB and to locate where to place openings in the back plate...
  16. Gedron
    31 Oct 2003
    Whew, particle board. That sucker is gonna be HEAVY. What are you thinkng about for the finish? Did I hear painting? Thats gonna take alot of work to make it look right. Grab a small sample peice and play with it.... probably going to need alot of some kind of filler to make it smoot and ready to take a good coat of paint. You might consider a veneer of some kind. It's not too expensive and it can give you a realy nice looking end product.
  17. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    whatever you do, dont water cool it. if any water leaks, your particle board will turn into mush. :blush:
  18. 0013
    0013 What's a Dremel?
    7 Mar 2004
    if any water leaks, his mobo will probably be toast anyway, doesnt look like a real problem that way to me :)
  19. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Ok, so - I have to ask. Why is it called you BEER server??? :D
    Looks cool so far, are you going to paint/seal both the Inside and Outside of that board?
  20. pranks7er
    pranks7er mange tout
    25 Dec 2002
    will the beer server contain beeeerrrrr droool lol :worried: cough cough :hehe:
