Electronics Beginning of some DIY speakers ***DONE!***
Discussion in 'Modding' started by cyberspyder, 16 Mar 2008.
  1. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    ***THOSE WHO ARE NEW TO THE THREAD, ALL UPDATES ARE POSTED IN THE FIRST POST TO MAKE YOUR LIFE EASIER. FOR SUBSCRIBERS, THE UPDATES ARE ADDED IN SUBSEQUENT POSTS (IE, SCROLL TO THE LAST PAGE)***
    For my wood shop summative, I've decided to make some DIY bookshelf speakers. Normally, MDF would be use, but to cut that during class time would require having respirators and goggles for all 24 guys. So no MDF. :( BUT I have scrounged up some 3/4" Baltic Birch/Russian Plywood as a substitute, which will get here on Monday. I plan to duplicate a set of Zaph's Bargain Mini's, although with a few tweaks of my own.
    1) Recess the baffle into the 4 sides
    2) Do a 3/4" roundover on the front of the sides
    3) Have a recessed back
    Preliminary side sketch:
    Front drawing (from Zaph's page):
    Baffle detail (also from Zaph's page):
    Dimensions are 9 1/4" deep, 10" tall, and 6 1/4" wide
    Crossover Components:
    -2x Bennic wirewound 4ohm resistors
    -2x Bennic wirewound 5ohm resistors
    -2x 10uF Solen/SCR/Bennic/Clarity Caps Poly capacitors
    -2x 2.7uF Solen/SCR/Bennic/Clarity Caps Poly capacitors
    -2x 3.3uF Solen/SCR/Bennic/Clarity Caps Poly capacitors
    -2x 1.5mH Solen/other brand 18-20ga inductors
    -2x 0.25mH (or close to) Solen/other brand 18-20ga inductors
    -2x 0.1mH Solen/other brand 18-20ga inductors
    -Speaker wire as ICs between the Xover & woofers/tweeters/binding posts
    -63/37 0.20-0.32" dia. solder
    Vendors: Solen, Madisound, PartsExpress, any other reliable DIY place
    Cabinet Parts:
    -5' x 5' 3/4" Baltic Birch/Russian Plywood (this is the size it comes in, you only need half of that for a pair, with lots to spare)
    -1" dia. x 4" Port tube (I couldn't find any 1" dia. PVC tubing at Home Depot or Rona, so I had to buy special port tubes)
    -2x MCM 4'' Shielded Aluminum Cone Woofer (Part #: 55-1853)
    ***Remember to get the source code on the flyer (here), as it'll get you a discount (only if the woofer is on sale)***
    -2x Aurasound NT1-204-8D 3/4" Titanium Dome Tweeter
    ***DO NOT TOUCH THE DOME***
    It is out of stock with a lead time of at least 4 weeks, a substitute (same size & mounting method), BUT IT IS NOT RECOMMENDED, is below
    -2x Dayton ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter
    -1/2" Sonic Barrier Dampening
    -1 1/4" Sonic Barrier Dampening
    OR
    -1/2" Chopped foam carpet padding doubled (or tripled) up
    ***To judge whether chopped foam is good or not, hold it up to the light. There shouldn't be many pinpricks of light shining through. This type of material is pretty much the only cost-effective damping material for speakers. It's really not that bad.***
    -5/16" OR 1/4", 1 1/2" long socket cap screws (black)
    -5/16" OR 1/4" Tee nuts
    -4x Binding posts
    -Various sizes of heatshrink
    LOG
    March 10, 2008
    -Ordered parts
    March 15, 2008
    -Some parts arrived :rock::
    -My plywood arrived, except it was the wrong thickness...:(
    March 18, 2008
    -Some crappy pics of my workspace:
    -PE order arrived, along with my wood!
    Hmmm, whats in the PE box?...
    Some books and...
    MY TWEETERS...
    Close-up of the protective cap & tweeter
    Along with my 18mm (sigh...they don't make it exactly 3/4") Baltic Birch
    Dramatic angle shot showing all 13 plies
    -My Mini-RCA IC parts arrived (Canare Star-Quad, Switchcraft connectors)
    -IC done (Canare StarQuad, Switchcraft connectors), Mini-RCA:
    -My woofers arrived and I began cutting the wood to width:
    -The last of my parts arrived, some perfect lay inductors and wirewound resistors from Solen
    -Soldered all the wires to the woofer and tweeter, all preliminary work done, have to wait until enclosure is done
    OOOH A BOX! What's inside it????
    Parts
    More parts...
    More parts....
    Speaker and tweeter tabs are a b!tch to solder and thread stranded wire through...I HATE THEM ALL.
    Some pics of my home workshop (ie, the dining room table and kitchen counter):
    April Fool's Day
    -OK, next update. First up, some better pictures of my workshop, and then some pics of the completed side and tip panels. Will get a new soldering iron tomorrow, wish me luck :)
    Brendan
  2. jhanlon303
    7 Sep 2006
    Do you have a tuned frequency for the Xover in mind. Small speakers won't do real bass well. Tuned port enclosure? should be fun to watch.
    John
  3. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Yes, the "crossover is an acoustic 4th order at 3kHz". Has been tweaked a bit to compensate for the different tweeter.
  4. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Interesting
  5. nickhelton
    nickhelton What's a Dremel?
    13 Feb 2008
    id been looking at doin this for quite some time.
    i will be watching :eeek:
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I would go for chipboard rather than plywood if you can't get or use MDF. Chipboard is better at absorbing stray waves than ply is.
  7. keir
    keir S p i t F i r e
    5 Oct 2003
    Interesting, I'm watching...
  8. jakenbake
    jakenbake full duplex
    5 Jun 2005
    sweet! got a schematic for the x-over?
  9. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Chipboard (or rather particle board) is surpassed by Russian ply and MDF. I will have foam dampening inside the cabinet to absorb the waves.
    @ jakenbake, not the most recent revision, as it's not proven yet to work seamlessly with the new tweeter, the old one is below (which works flawlessly with the Aura NT1, IF you can find them):
    Brendan
  10. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    ARRG, have to wait till tomorrow for the plywood to come...sigh. In the meantime, enjoy some crappy pics of my workspace:
    Brendan
  11. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Some books and...
    MY TWEETERS...
    Brendan :rock:
  12. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    Chipboard is a horrible material for speaker enclosure construction. Of the readily available materials out there MDF/HDF and Marine ply (baltic birch) are by far the best to use.
    That shop should be able to handle the MDF dust just fine with all that air filtration, as long as the filters are clean. However, you already have the ply and that will work just fine as well.
    Instead of using carpet foam get some polyfill from a local store such as Wal-Mart. They will have it in big rolls in the fabric section. It's very cheap and works very well.
  13. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    I'm getting the carpet padding for free, so I guess I'll go with it. BTW, wassup fellow canadian?
    Brendan
  14. jakenbake
    5 Jun 2005
    you gonna start building this weekend?
  15. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    At school, so during the week :)
  16. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    What are your plans for the finish? Going with a veneer or paint?
  17. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    No veneer, as the birch looks really good on its own. Maybe some Varathane for the sides and some matte black paint for the baffle.
    Brendan
  18. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Brendan
  19. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Comments please!
    Brendan
  20. jakenbake
    5 Jun 2005
    That looks like Dynamics homework under there. Ew.
