Electronics Beginning of some DIY speakers ***DONE!***
Discussion in 'Modding' started by cyberspyder, 16 Mar 2008.
  1. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Yes, I hate it too... Anyways, on another note, my woofers arrived and I began cutting the wood to width:
    Brendan
  2. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    ALOT of double posting going on here! Why?
  3. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Well it's easier for people who are new to the thread, since all the updates are compiled into one post, while the ones that have seen it will most likely scroll to the last page for updates. On another note, the last of my parts arrived, some perfect lay inductors and wirewound resistors from Solen, and I did all the soldering to the speakers, which will make it easier in the long run when it comes time to assemble it.
    OOOH A BOX! What's inside it????
    Parts
    More parts...
    More parts....
    Speaker and tweeter tabs are a b!tch to solder and thread stranded wire through...I HATE THEM ALL.
    Some pics of my home workshop (ie, the dining room table and kitchen counter):
    Brendan
  4. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    Be careful, it's not a good idea to solder tweeter connectors as the voicecoils aren't always hefty enough to take the heat.
  5. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Hmmmm, I guess we'll have to see if it's damaged when I fire it up. Maybe a heatsink next time? Or a hotter iron?
  6. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Or crimp like connectors??
  7. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    They work loose. Soldering is generally best.
  8. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    April Fool's Day
    -OK, next update. First up, some better pictures of my workshop, and then some pics of the completed side and tip panels. Will get a new soldering iron tomorrow, wish me luck :)
    Brendan
  9. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    -Update again...Mitres completed, Xover about to get soldered together.
    Brendan
  10. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Nice size speakers... you should make 5 of em or 6 plus a sub..
  11. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    -Xover boards cut out from Masonite, going to be friction-fitted in the cabinet
    Brendan
  12. _-..zKiLLA..-_
    _-..zKiLLA..-_ What's a Dremel?
    8 Jan 2008
    gonna be some high quality speakers, looks pretty expensive too :D its all worth it. i love loud music
  13. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    UPDATE!!!!
    April 10, 2008
    -Finally finished both Xovers, they are guaranteed no to fall off...REMINDER TO PEOPLE WHO WANT TO BUILD XOVERS, DO NOT DO WHAT I DID AND ROUTE THE WIRES ABOVE EVERYTHING...IT WAS A PAIN IN THE ASS TO SOLDER AND GLUE TOGETHER. MOUNTING IT USING THE TYPICAL PCB MOUNTING METHOD (IE. DRILLING HOLES LIKE A PERFBOARD) IS MUCH, MUCH EASIER. Some pics, along with my naked speakers & tweeters.
    Brendan
  14. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Another update! (God, don't you just love them?)
    April 11, 2008
    -One enclosure done, and mocked-up with baffle & Xover as reference; the other one will be completed on Tuesday, as I don't have class until then. Oh, and a small change in plans...originally I was aiming for varnish, but after trying it out on a scrap piece, I can safely say that it looks like crap. So, no varnish, but staining is the next option. Going to pick up some of this Golden Oak stuff next time I go to Home Depot, as well as my carpet padding.
    I'd say it turned out pretty nice, all the mitres came out perfectly, everything is square...all that's left is to route the roundover/chamfers and drill out the holes.
    Brendan
  15. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Looks awesome. You're right, those mitres are really spot on. Geez that reminded me how how much I suck at woodworking lol
  16. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    I went to Home Depot today for some stain and carpet padding. Outcome? A can of Golden Oak, and no carpet padding, because 'they couldn't cut section of a roll for me and there weren't any scraps'. Yea, bullcrap. Anyhow, will try the carpet store beside my mom's workplace...
    Brendan
  17. NZ_mod_man
    26 Aug 2007
    Nice! Those are looking like quality speakers already! They are going to look mint once done!
  18. ROB 636
    ROB 636 Ski-Ba-Bop-Ba-Dop-Bop
    22 Feb 2008
    The speaker box is nice and square very professional.
    I don't know much about electronics, what are the red wire coils for?
  19. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Those are the inductors, which act as a filter that passes low frequencies but chokes off high ones.
    April 15, 2008
    -OHHHH I'M PISSED. The forstner bit I'm using (1 3/8") is a millimeter TOO SMALL FOR MY RETARDED TWEETERS. Whoever made the tweeter must like to torture people. The hole is fine for my port, but it looks like I'll have to sand/file off the excess by hand or a drum sander...(*!@&(^!$#(^!#(^$(
    ARRRG!!!!!! GET IN THE HOLE YOU STUPID POS!!!:mad::mad::mad:
    That is all...
    Brendan
  20. jakenbake
    jakenbake full duplex
    5 Jun 2005
    get a cheap new hole saw. they are only like $5 (US)
