Hardware Belkin N1 Vision
Discussion in 'Article Discussion' started by Guest-16, 17 Jan 2009.
  1. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2009/01/17/belkin-n1-vision/1
    Belkin's N1 Vision modem router brings something different to the world of home networking with an LCD screen, as well as support for Gigabit networking and Wireless 802.11n. We take it for an extended test drive and see if it’s just ticking the boxes, or is a genuinely quality bit of kit.
    :clap:
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    This looks really promising, I like it a lot! : )
  3. samkiller42
    25 Apr 2006
    I have been looking to get the ADSL 2 version for some time now, and now with this review, it's pretty much sold.
    Now to save up for it.
    Sam
  4. The boy 4rm oz
    10 Apr 2008
    I have the standard ADSL version and it's a great router, especially since dad paid lol.
  5. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    its a shame that most routers are basically shite until you get special firmwares for them. In this case a beta which should have been released when the damm thing was made avaliable!
    Ive got a netgear wireless N router that i use as a basic wireless access point but even THEN its unreliable. Good job i have a custom build PC as a router instead of the useless router.
  6. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    ive had one of these for a while, theyre not bad at all
  7. dmak
    dmak What's a Dremel?
    1 Apr 2006
    can you load ddwrt on it?
  8. tominated
    tominated What's a Dremel?
    28 May 2008
    looks like i found a new gadget to beg for dad to buy
  9. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Whatever happened to routers that were just routers?
    Everything these days has a router, a switch, a wireless AP, and who knows what else. Then, the firmware gets ignored untill the last minute, and everything sucks.
    Seriously. It's got gigabit. So what? I can buy an 8 port gigabit switch and a cheapie linksys router (and put linux on it) for less than the Belkin N1 costs (and if you really want wireless N, add an separate access point, but if you're actually using gigabit's bandwidth, wireless is a waste anyways). That way, you get more ports, a much better router, and way more configuration options. Hell, for that price, you could almost put together a small intel atom based PC-router, and then you could *really* configure anything.
  10. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    I'm after a new ADSL2+ Router with Wireless 'N'. This looks like it could fit the bill?
    Does it has a QOS so you can prioritise gaming traffic?
    Would anyone have any suggestions for any other routers or go for this one?
  11. iwog
    iwog Linux cursed
    14 Jun 2007
    I have one question, as I have a mix of G and N wireless devices in the house will the N1 vision downgrade the N wireless when a G device tries to connect, or will it allow both devices to operate at their full speed?
  12. lewchenko
    lewchenko Minimodder
    17 Dec 2007
    Wolfe, I think you have missed the point about why someone may want a product like this.
    The vast majority of people do not want to buy a cheapie linksys router and put linux on it then couple it to an 8 port gigabit switch. (My time is too valuable to be messing around with stuff like that). Most people dont mind paying a little bit more and getting a fully configured package all in one - and this one does have features that are desirable.
    I did consider this router a while ago, but then read a review that said the firmware was bugged beyond belief, and it was unreliable. Sale lost... instantly. ~really Belkin.... get real.
    And yet despite the fact that the new firmware (BETA... not even properly released yet!!) fixes the issues, Im still going to hold off. The economy means this would be a luxury purchase now, not a nice to have...
    My trusty old Netgear DG834 lives to see another day. Wow that router is like 90+ years old in 'router years' now.. and still works fine!!
    >>>Iwog, most routers have combination settings, so it would be N + B +G or N +G or N to choose from. (My ancient netgear does this with B+G)
  13. p3n
    p3n What's a Dremel?
    31 Jan 2002
    How can you give it 9/10 ease of use when it 'requires' a firmware update?
  14. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    not sure why you think it is hard to do that (download update, loginto router, click browse and click upload/update) at best its an 5 min job
  15. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    Had this router for ages and it is really nice good to see a review of it as never saw a good one before i got it
  16. Jipa
    5 Feb 2004
    Kinda fancy, innovativel and also maybe even practical, I like it!
    Have had some issues with my router lately.. lets see if it's dying already. Last one got blasted (literally) when it started losing the connection every time the hoover/lamp/what ever larger electic stuff was switched on.
  17. Sebbo
    Sebbo What's a Dremel?
    28 May 2006
    used this router for the last year, and it was utter sh*te. a couple of times it reset itself to factory defaults when i was just changing a setting in the port forwarding. a firmware update seemed to fix the problem (or maybe it was just completely rewiring the network so i wasn't actually using the n1 at all), only for it to crap itself some months later and refuse to boot. replacement we got from belkin seemed to have memory leaks as it would occasionally completely freeze up.
    after that experience, i think i'll stick with D-Link (shocking as that may be)
  18. Baz
    Baz I work for Corsair
    13 Jan 2005
    Sebbo - The release firmware for the N1 Vision is, admittedly, utterly poo, as we mentioned in the review - it's bug filled and totally unacceptable. Thankfully though the beta firmware fixed ALL the issues we had with the router, and as it's a tiny download and an easy fix, we decided it shouldn't negatively effect our opinion, although was worth mentioning.
  19. Impossible
    Impossible What's a Dremel?
    23 Jun 2002
    The high price tag puts me off, I would have paid around £60/70 quid for these features asI want to merge my gig switch/ap/adsl hardware into one.
    If a version of WRT was cooked for it, then that would be bliss, but afaik theres no adsl functions in WRT......please someone prove me wrong (I miss WRT!)
  20. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Me thinks Belkin paid Bit 44p to write such a positive review ;)
Tags: Add Tags
